Old 08-28-2023, 12:34 AM   #1
TSF
Default water pump problem
The water pump in my 2018 Carado Banf makes noise when trying to pump, but pumps very little; more to the sink over the toilet, less in the dish sink.
Suggestions? Where to buy a new one?
TSF is offline   Reply With Quote
Old 08-28-2023, 02:22 AM   #2
Blueboy1's Avatar
Hi, check for sludge on the water inlet of the pump. There should be a fine screen that gets easily clogged.
Blueboy1 is offline   Reply With Quote
Old 08-28-2023, 05:17 AM   #3
if the filter doesn;t fix it, the diaphragm in the pump can get clogged with mineral deposits ( hard water) take off end cover and remove any grit or scale.
if you need a pump there are replacment shur flow models on amazon for pretty good price
Old 09-03-2023, 06:39 PM   #4
I have a Hymer Aktiv that was made by the same company. My water pump was clogged with small bits of plastic from when the water tank was drilled. To check for this, you'll need to disassemble the pump head. Look specifically at the rubber poppet valves. Also, check for debris in the faucet screen and where the hose attaches to the faucet wand.
JohnP is offline   Reply With Quote
water pump
