Old 07-18-2019, 06:00 PM   #1
Default test, pls disregard
111 test, pls disregard
98LeisureTravelDodge is offline   Reply With Quote
Old 10-10-2019, 01:06 PM   #2
Dogman's Avatar
As to 98LeisureTravelDodge if you want you can change to a shorter USER NAME in you USER CP set up area or ask an ADMINISTRATOR to help change or not.
Welcome to the IRV2.com FORUM(S).
When you first enter this group a new Member may feel a bit overwhelmed by all the forums you can find here. First, you need to set up your USER CP
Once you open and start a menu will open on the left side just take it all in the step-by-step top to bottom.
NEXT, you will find this forum is made op of 14-Forums broken into four-part forums. First is the HOME, top left above the member's menu. This forum is very helpful to new members to learn and become more familiar with overtime.
NEXT TO HOME is FORUMS on the top left covering Community, RV Lifestyles, Regional and RV Camping. and to the right of this is RV Forums.
RV FORUMS on the top left covers a lot about TRUCKS, Conversations, MVT's, HDT's, Travel Trailers/5th Wheel Chassis & TECH stuff, Chassis CLUB, RV SYSTEMS, Powertrain Garage.
Then you have the OWNERS FORUMS Covering Registry, A-M, and N-Z.
Now if you pan down to the bottom of the page you will find other FORUMS and if you know or have a Class B, you can direct or join the CLASS B FORUMS at http://www.ClassBForum.com
So welcome again, I hope you join in the fun and share your knowledge by helping new members find their way in this forum as you would in, any RV Park. Again make sure to set up your USER CP as this is helpful to you and other members. Again if you enjoy or think of starting your own RV Blog you can do that here as well above on menu bar is BLOGS Enjoy and safe TRAVELS. You can also find RV PARKS above in CAMPGROUNDS.
2021 Coachmen Galleria 3500XD, 24FL, with Li3.
We are H.L. and Jan, from the Sunshine State on Florida's west coast.
"Remember every camping trip is an outdoor adventure and begins and ends with a road-trip. Drive safely with your family cargo."
Dogman is offline   Reply With Quote
