Old 06-29-2021, 07:06 AM   #1
Default Rear Table - what does floor mount look like
Hi All,
I'm back at it. Can you send me pics for what I should expect the rear table floor mount to look like as our carpet and mount has never been installed. Our carpet has never been cut, however there seems to be some sort of base there but no hole - maybe there is a floor plug there? The front table in our rig has a recessed hole for the table's pool to be inserted and when its not in use we have a plug that fills the floor hole - is it the same for the rear table?
Santee2005PWTD is offline   Reply With Quote
Old 06-29-2021, 08:02 AM   #2
in the rear ( on my 2006 lexor) the mount is screwed through the carpet into the floor with 6 or 8 wood screws.
kind like this one:
https://www.amazon.com/AP-Products-1...87200366&psc=1
the round aluminum mount stands proud of the floor and after stumbling on it ( trying to be quiet at night- and being NOT quiet) I removed it
we don't use our tables preferring to use a picnic table or a tray on the lap
this has opened up storage space- the bottom of our armoire has a sliding basket which holds the pot and pans N stuff. above that we have a couple of shelves.
the armoire is now the pantry
under the base of that a cabinet is the water pump- also a good hidey hole for valuables/passports.
also stored is the top drawer unit ( from the back) and the shower pan- that storage space is used for a small solar cell
If you are big on tables, you can also get a base to use your mast and table outside or get one of the above and screw it to a piece of plywood
https://www.campingworld.com/folding...ble-legs-bases
Old 06-29-2021, 10:36 PM   #3
Yep, I can see the table's base being a serious tripping hazard, I don't need a table that badly; this probably the reason our rig's original owner never had it installed.
Old 06-29-2021, 11:04 PM   #4
probably handy for putting practice
Old 06-30-2021, 12:45 AM   #5
thanks, I needed a good laugh...., the bottom of my closet, the one behind the driver seat holds the important stuff - mixers and our wine.
Old 06-30-2021, 02:52 AM   #6
I also removed the floor stand for our table ('2012 AS Avenue). As mentioned, it was in the way, post and table has to be removed when driving, and then stowed in the limited space available in class b.
We eat just holding our plates. For a cup holder, I ordered these. They wedge between the seat and outer walls and are also nice for holding cell phones, glasses, etc.
https://www.amazon.com/gp/product/B0...ZUYQ0KOV&psc=1
Old 07-04-2021, 10:52 PM   #7
I got rid of mine too, and also the carpet. I have a Lagun table back there now
