Old 11-27-2006, 06:46 AM   #1
Default RV Fire Safety Tips
RV Fire Safety Tips
By Mark Polk
Did you know that there are close to 20,000 reported RV fires each year? A large percentage of these fires are transmission related fires on motor homes. Automatic transmission fluid leaking from the transmission can ignite, and quickly spread if it contacts any portion of the exhaust system. Before traveling in your RV inspect the underside for any signs of fluid leaking. Have any potential leaks checked out and repaired immediately.
Over 25 percent of RV fires are caused by shorts in the 12-volt electrical system. Not only do you need a fire extinguisher, you need to inspect it before each trip to make sure it is charged. Look to see if the arrow is pointing in the green area in the sight gauge. If it reads empty or needs charging replace it or have it recharged immediately. If it’s a dry powder type fire extinguisher the arrow pointing in the green doesn’t always guarantee that it will work. Every month you should turn dry powder extinguishers upside down, tap on the bottom of the extinguisher and shake it. It should sound hollow, sort of like a drum. If not, continue tapping on it until it sounds hollow and the powder that settled on the bottom is released.
You need to have an emergency escape plan. The National Fire Protection agency requires that RV’s have emergency escape windows. Make sure everybody knows where the escape window is located and how to use it. It’s a good idea to practice using it so you are familiar with how to get out of the RV in case of an emergency. You should have an escape plan for the front of the RV and the rear of the RV.
Happy Camping!
Mark
Copyright 2006 by Mark J. Polk, owner of RV Education 101
RV Expert Mark Polk, seen on TV, is the producer & host of America's most highly regarded series of DVD's, videos, books, and e-books. Sign up for your free "RV Education 101" Newsletter rveducation101.com/email/
Mark Polk is a retired U.S. Army Chief Warrant Officer Three, specializing in wheeled and track vehicle fleet maintenance operations. Polk owns and operates RV Education 101, (based in North Carolina) since 1999, and also has an extensive RV background working in RV service, sales and management. Polk has a degree in Industrial Management Technology with 30 plus years of experience in maintenance includes working as an RV technician, a wheeled vehicle and power generation mechanic, an automotive maintenance technician, Battalion and Brigade level Maintenance Officer, an RV sales manager and also in the RV financing department as the Finance & Insurance manager. www.rveducation101.com/
Article Source: http://EzineArticles.com/?expert=Mark_Polk
