Old 11-27-2006, 06:48 AM   #1
Default RV Awning Operation Info
By Mark Polk
There are several different types of awnings and awning manufacturers. This is the awning operation checklist from my Checklists for RVers E-book. The purpose of this checklist is to give you a basic guide to follow when opening and storing your retractable patio awning. It may not cover every item as it pertains to your awning; so only use the checks that apply to your particular awning.
Most awnings have some type of travel locks about midway up, on both main awning arms. These locks assist in storing the awning to the side of the RV while traveling. Release these locking mechanisms.
Behind both main awning arms, on the support arms, there will be a knob that should be hand tight. Loosen both of these knobs.
Look up at the end of the awning roller tube on the right hand side, towards the front of the RV. You will see a small lever. This lever is what locks the roller tube to the side of the RV. Take your awning rod and with the hooked end reach up and pull the lever down to release the roller tube.
Look up, around the middle of the roller tube, and you should see the end of the awning strap, with a loop in it. With the hook end of your awning rod reach up and hook the awning strap loop. Using the awning rod, pull the awning strap down until you can reach it with your hand. The awning roller tube should release and pull freely from both ends. Continue pulling down on the strap until the awning fabric and tube are fully extended.
Now, the inner support arms, where you loosened the knobs, should slide freely to the top of the main arms and lock into place. Do this on both ends. When they are locked in place, starting on either end, take one hand and pull down on the main awning arm until the awning fabric is taught. With your other hand reach up and hand tighten the knob. Repeat this on the other end.
On the side of each main arm you will notice a lever. Starting on either end of the awning, take one hand and put it on the front of the main arm and take the lever with your other hand. Raise the main arm up to the height you want the awning, using the lever to help lift it. When you lower the lever it will lock into the closest adjusting hole on the arm where you release it. Repeat this on the other end.
Caution: Do not get your fingers or hands close to any moving or sliding parts.
Retracting your Patio Awning
Put one hand on the front of the main awning arm and the other hand on the lever on the side of the arm. As soon as you pull out on the lever the awning arm will begin to lower. Caution: keep fingers and hands away from moving and sliding awning parts. Using the lever for support slowly lower the main arm until it stops. Repeat on the other end.
Reach up and loosen the knob on one of the support arms. On the front of the main arm, towards the top, pull the release latch out that is locking the support arm in place. Holding the latch out begin to slide the support arm down the main arm. Continue to slide it all the way down until it stops. Repeat on the other end. Again watch your fingers.
If you are retracting the awning by yourself take your awning rod in one hand and with your other hand take the awning strap and slide it all the way down the awning tube, to where the awning lock lever is located, towards the front of the RV.
Pull down on the awning strap, applying enough pressure, until you can release the awning lock lever. Caution: as soon as the lever is released the awning tube will begin to retract. These tubes have springs that are wound with tension. Hold the strap securely and release the locking lever. Continue to hold the strap firmly and work it back to the middle of the awning tube by sliding it in the groove.
When the awning strap is close to the middle of the roller tube slowly let the awning begin to retract by easing off the awning strap. Place the hook end of the awning rod into the loop of the strap and continue to retract the awning until it is in the stored position. Do not let go of the strap too early. The awning can violently hit the side of the RV causing damage to the awning and/or the RV.
Secure the travel locks on both main arms and hand tighten both knobs on the back of the support arms.
Awning Tip: If somebody is assisting you the 3rd and 4th steps are much easier. Locate the awning strap in the middle of the awning tube. Have the person assisting you hold tension on the strap while you release the awning lock lever. Then, using the awning rod the person assisting you can slowly allow the awning to retract.
Well that about does it. With the proper care and a little preventive maintenance you and your RV awnings will have it made in the shade.
Happy Camping!
Mark
Copyright 2006 by Mark J. Polk, owner of RV Education 101
RV Expert Mark Polk, seen on TV, is the producer & host of America's most highly regarded series of DVD's, videos, books, and e-books. Sign up for your free "RV Education 101" Newsletter rveducation101.com/email/
Mark Polk is a retired U.S. Army Chief Warrant Officer Three, specializing in wheeled and track vehicle fleet maintenance operations. Polk owns and operates RV Education 101, (based in North Carolina) since 1999, and also has an extensive RV background working in RV service, sales and management. Polk has a degree in Industrial Management Technology with 30 plus years of experience in maintenance includes working as an RV technician, a wheeled vehicle and power generation mechanic, an automotive maintenance technician, Battalion and Brigade level Maintenance Officer, an RV sales manager and also in the RV financing department as the Finance & Insurance manager. www.rveducation101.com/
Article Source: http://EzineArticles.com/?expert=Mark_Polk
