Old 10-29-2006, 02:59 PM   #1
Default Pleasure-Way Industries Inc. - Recalls
Make / Models : Model/Build Years:
PLEASURE WAY / EXCEL 1995-2000
PLEASURE WAY / LEXOR 1995-2000
Manufacturer : PLEASURE-WAY INDUSTRIES LTD.
NHTSA CAMPAIGN ID Number : 01V135000 Mfg's Report Date : APR 19, 2001
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGS
Potential Number Of Units Affected : 1197
Summary:
VEHICLE DESCRIPTION: MOTOR HOMES. THE REAR BRAKE LINE MAY NOT BE PROPERLY FASTENED TO THE REAR AXLE IN THE ORIGINAL LOCATION. OVER TIME THIS COULD CAUSE FAILURE OF THE REAR BRAKING SYSTEM.
Consequence:
THIS CONDITION CAN RESULT IN DIMINISHED BRAKING, INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL INSPECT THE REAR AXLE BRAKE LINES TO ENSURE THEY ARE PROPERLY CLIPPED TO THE REAR AXLE, HAVE NOT BEEN DEFORMED, AND THAT THERE IS NO INTERFERENCE BETWEEN THE BRAKE LINES AND ANY OF THE REAR AXLE OR SUSPENSION COMPONENTS. IF THERE IS ANY DEVIATION FROM THE FACTORY LINE ROUTING AND FASTENING OR IF ANY OTHER DAMAGE, INTERFERENCE OR DEFORMATION IS APPARENT, DEALERS WILL RE-ALIGN, SECURE, AND REPLACE THE LINES IF NECESSARY. OWNER NOTIFICATION BEGAN MAY 1, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT PLEASURE WAY AT 1-306-934-6578.
Notes:
ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 03:15 PM   #2
PLEASURE WAY / EXCEL 2001-2002
PLEASURE WAY / LEXOR 2001-2002
NHTSA CAMPAIGN ID Number : 02V259000 Mfg's Report Date : SEP 16, 2002
Component: ELECTRICAL SYSTEM:WIRING:FRONT UNDERHOOD
Potential Number Of Units Affected : 411
Summary:
ON CERTAIN MOTOR HOMES, THE UNDER HOOD CHARGING SYSTEM WIRING MAY BE IMPROPERLY ROUTED AND COULD COME IN CONTACT WITH OTHER UNDER HOOD COMPONENTS.
Consequence:
THIS COULD RESULT IN A POSSIBLE RISK OF DAMAGE TO THE WIRE'S PROTECTIVE COVERING FROM AN ELECTRICAL SHORT.
Remedy:
DEALERS WILL INSPECT THE WIRING AND, IF NECESSARY, REPLACE THE WIRE AND RE-ROUTED. OWNER NOTIFICATION BEGAN SEPTEMBER 17, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT PLEASURE-WAY AT 1-306-934-6578.
Notes:
ALSO, CUSTOMERS CAN CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 10-29-2006, 03:35 PM   #3
Make: PLEASURE-WAY
Model: VAN
Affected Year(s): 1988 1989 1990
Units Affected: 212
Transport Canada Recall #: 1990177
Manufacturer:
Campaign Code:
Recall Details
Note: Class B motorhomes
These vehicles do not comply with C.M.V.S.S. 209 - seat belt assemblies and 210 seat belt assembly anchorages.
Old 12-09-2008, 04:33 AM   #4
Default Re: Pleasure-Way Industries Inc.
Vehicle Make / Model: Model Year(s):
PLEASURE WAY / ASCENT 2007-2008
PLEASURE WAY / PLATEAU 2007-2008
Manufacturer: PLEASURE-WAY INDUSTRIES LTD. Mfr's Report Date: AUG 13, 2008
NHTSA CAMPAIGN ID Number: 08V421000 N/A
NHTSA Action Number: N/A
Component: EQUIPMENT:MECHANICAL:CARRIER/RACK
Potential Number of Units Affected: 127
Summary:
PLEASURE-WAY IS RECALLING 127 MY 2007-2008 ASCENT AND PLATEAU CLASS B MOTOR HOMES EQUIPPED WITH A REAR HITCH MOUNT TIRE CARRIER. THESE MOTOR HOMES FAIL TO CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, 'LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT.' THE TIRE CARRIER IMPEDES THE TAIL LIGHT VISIBILITY.
Consequence:
POOR REAR TAIL LIGHT VISIBILITY COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL REMOVE THE HITCH MOUNT SPARE TIRE CARRIER AND ALL RELATED HARDWARE. THE RECALL BEGAN ON SEPTEMBER 2, 2008. OWNERS MAY CONTACT PLEASURE-WAY AT 1-800-364-0189.
Notes:
CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO http://WWW.SAFERCAR.GOV.
Old 12-09-2018, 04:13 AM   #5
Summary:
Consequence:
Remedy:
Notes:
Fire in 1998 dodge PleasureWay
Raywinter is offline   Reply With Quote
Old 12-09-2018, 04:59 AM   #6
Welcome to the forum Raywinter!
You had a fire, or is there another recall?
