Old 06-02-2008, 07:50 PM   #1
Default Dometic Voluntarily Expands Refrigerator Recall
Enter your fridge model and serial number at the following link:
http://www.dometicusa.com/recall.php
I think it only affects two door fridges but it's worth checking anyway.
Dometic recently expanded its recall on a population of two-door refrigerators. The original recall included some two-door refrigerators manufactured between April 1997 and May 2003. The recent expansion of this recall now includes the same two-door refrigerators, manufactured between June 2003 and September 2006.
Old 06-19-2008, 03:53 AM   #2
Default Dometic Recall Number: 08E032000
Make / Models : Model/Build Years:
DOMETIC / NDR1062 9999
DOMETIC / RM2652 9999
DOMETIC / RM2662 9999
DOMETIC / RM2852 9999
DOMETIC / RM2862 9999
DOMETIC / RM3662 9999
DOMETIC / RM3663 9999
DOMETIC / RM3862 9999
Summary:
DOMETIC HAS REPORTED A SAFETY RELATED DEFECT COVERING 745,574 TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN JUNE 1, 2003 AND SEPTEMBER 30, 2006, WITH SERIAL NOS. 320XXXXX THROUGH 352XXXXX; 401XXXXX THROUGH 452XXXXX; 501XXXXX THROUGH 552XXXXX; AND 601XXXXX THROUGH 639XXXXX, INSTALLED IN CERTAIN RECREATIONAL VEHICLES AS ORIGINAL EQUIPMENT AND SOLD AS REPLACEMENT EQUIPMENT. A FATIGUE CRACK MAY DEVELOP IN THE BOILER TUBE WHICH MAY RELEASE A SUFFICIENT AMOUNT OF PRESSURIZED COOLANT SOLUTION INTO AN AREA WHERE AN IGNITION SOURCE (GAS FLAME) IS PRESENT.
Consequence:
THE RELEASE OF COOLANT UNDER CERTAIN CONDITIONS COULD IGNITE AND RESULT IN A FIRE.
Remedy:
THE VEHICLE MANUFACTURERS WILL NOTIFY OWNERS OF RECREATIONAL VEHICLES THAT HAD THE REFRIGERATORS INSTALLED AS ORIGINAL EQUIPMENT AND DOMETIC WILL NOTIFY OWNERS OF THE AFTERMARKET REFRIGERATORS. DOMETIC WILL INSTALL A SECONDARY BURNER HOUSING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING APRIL/MAY 2008. OWNERS MAY CONTACT DOMETIC AT 888-446-5157.
Notes:
CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO http://WWW.SAFERCAR.GOV.
Old 06-19-2008, 04:04 AM   #3
I had the recall "repair" work done at
Tom's RV Service
http://www.tomsrvservice.bc.ca/
894 Van Isle Way,
Victoria, B.C. V9B 5R8
250-478-6527
FAX: 478-6537 CELL: 883-6377
OPEN 8:00am to 5:00pm Monday to Friday
8:00am to 3:00pm Saturdays
Toll Free: 1-866-530-6527
The shop foreman doesn't normally work Saturday's but he made a point to be there to make sure it was done right. That's great service!
Before photos:
After photos:
Here's a closeup of Dometic's thermofuse:
