Old 03-17-2017, 03:58 PM   #1
Default WTB: Seat belt buckle
I'm needing a seat belt buckle that is at the third seat in a Roadtrek 2000 Chev 200. There is a number on the clip(attached to the belt). "IN 727 14"
I have no idea what other RT-s this may have been a part of. No luck on Amazon/interwebs.
The belt and clip are just fine. I just need the buckle ("female") part.
Thanks.
irideana14 at inbox dot com
call or text 352 973 8lO3
Old 03-17-2017, 04:36 PM   #2
I would try the junk yards.
It is a standard GM thing, a buckle from any car should do.
Old 03-17-2017, 11:46 PM   #3
It's not the same as the front GM belts. It's something apparently RT installed. I'm trying to avoid buying it from RT, probably $437 knowing how things get marked up.
Thanks.
Old 03-23-2017, 05:02 AM   #4
Steve, Are you talking about the part attached to the shoulder harness? I may have one! I will check tomorrow and get back to you with a picture ( if I can figure out how). My RT is a 2001 200, so chances are good it's the right thing.
Maureen
Fiona2011 is offline   Reply With Quote
Old 03-23-2017, 07:35 AM   #5
I'm looking for the buckle that the clip slides into to "buckle up"' for the second row seat shoulder harness.
Good luck on pic. If it's easier, text pic to 352 9seven3 8lO3.
Thanks. And welcome aboard!
Old 03-23-2017, 11:56 PM   #6
Texting you the pics. One of the "male' part as well to see if my extra buckle will work for you. I thought it was strange that there is an extra harness and buckle located inside the cabinet behind the driver's seat. I suppose it's because one could have a 4th chair there if you took out the cabinet.
Maureen
Old 03-24-2017, 12:57 AM   #7
Maureen, thank you. Good "chatting" with you.
Old 03-28-2017, 01:04 AM   #8
Buckle arrived today, thanks Maureen.
Old 03-28-2017, 01:08 AM   #9
Yay! Enjoy your trip!
