Old 08-07-2021, 01:15 AM   #1
Default Rialta Transmission
Purchased 1997 Winnebago Rialta 2 months ago. Took it for regular maintenance and mechanic sprayed silicone in the gear shift. After that when I tried to put in reverse gear engine shuttered and shut down. Able to get started and get into drive after few tries and the lost power again. Towed to VW dealer says thinks needs transmission but did not open the transmission. Any suggestions or thoughts
Joeyjack is offline   Reply With Quote
Old 08-07-2021, 03:22 AM   #2
detail the "regular maintenance"
what you write makes me think motor trouble...does it have oil ?
is it getting fuel ?
mike
Old 08-12-2021, 12:17 AM   #3
What was opinion of mechanic that did the service? Silicone in shifter would have no relation to the problem you’re describing. Any Check Engine light?
Renzo is offline   Reply With Quote
Old 08-12-2021, 01:39 PM   #4
mloganusda's Avatar
Join the Rialta group for more info on problems.
https://groups.io/g/Rialta
Winnebago Rialta Motor Home
https://www.fcpeuro.com/Volkswagen-p...ission/?page=2
https://europarts-sd.com/
