Old 03-03-2021, 08:21 PM   #1
Default Onan Generator
Generator (Cummins Onan QG 2800) removed from 2020 Travato. $1400 OBO. Less than 10hrs of use. Starts and runs perfectly. No damage. Removed to install lithium batteries. Located near Sacramento, CA. Pick up only.
Ready2roll is offline   Reply With Quote
Old 03-03-2021, 10:44 PM   #2
I have a 2016 PW Lexor TS. Did you install UHG? Why get rid of the generator? Just curious? Thanks
Old 03-04-2021, 12:54 AM   #3
Not sure what UHG is?
As noted in the post, I removed it to install additional batteries. I rarely used it, usually only to run the microwave.
SunCoast is offline   Reply With Quote
Old 03-04-2021, 01:10 AM   #4
UHG is second alternator(high output) so you can charge your lithium using chassis engine. Engine usually has to idle a bit higher rpms.
How are you planning on charging your lithiums? The standard alternator from Promaster? How large is your lithium battery bank? Thanks for the information.
Old 03-04-2021, 06:43 AM   #5
Thanks. I am aware of the second alternator setup. The lithium version of the Travato uses that (48V I believe). For me it was too complicated, expensive and in the end unnecessary for my setup. My use typically does not use anywhere near the capacity of my pack (500 amp-hr @ 12V; on a typical day I might use 10% of that) and involves some driving each day so I was less interested in having a fast recharge (I also have a couple hundred watts of solar). I decided on using the stock alternator with a 60 amp DC-DC converter to ensure I don't overtax the alternator. I did consider using a Battery Isolation Manager (Precision Circuits) to manage it but didn't like that it would fully load the alternator and then suddenly disconnect potentially creating a voltage spike that could damage the alternator and other electronics.
for sale, generator
