Old 03-20-2020, 03:33 PM   #1
Default Need LP part for 2013 Roadtrek CS
We need the 80% fill valve for the Armebe brand 16 gal propane tank on our Roadtrek 2013 CS Adventureous If no one has that, we will buy the entire tank which is Roadtrek part number 26016021 Tank-LP-12x36 which Roadtrek no longer carries.
Any help is appreciated.
Mike Keyes’
Mikeyes@charter.net
mikeyes is offline   Reply With Quote
Old 03-20-2020, 03:46 PM   #2
mloganusda's Avatar
Just highlighted you requirements for web search and found this:
https://www.bing.com/search?q=80%25+...c3f13ccdc51f7f
Try a web search, go to a local propane dealer, or RV repair place. To replace the valve, you need to go to a propane dealer for them to replace the valve.
MLogan
Smyrna, TN
Old 03-26-2020, 06:39 PM   #3
As mentioned, go to propane dealer. I went to Amerigas for my valve. That's what they do for a living. The guy I had was an old timer, maybe 40 plus years experience. I was curius how long the actual tank should last, he replied "Forever". This guy knew propane and everything about it from A-Z
Old 11-23-2020, 09:48 PM   #4
Now if I could get my RV guy to connect with your Propane guy, I be all set!!!
