Old 10-14-2018, 09:30 PM   #1
Default Need a new LP tank gage
Hi Guys,
The LP tank gage fell off my 2005 Pleasureway Excel TS.
I’s like to replace it, but I do not know the brand or model number. My RV tech looked underneath the van, at the LP tank, to get an idea; however, no success. And so I am driving around hoping I do not run out of propane. Clearly,
I have to replace the gage asap. Any ideas?
a.brusanowski is offline   Reply With Quote
Old 10-14-2018, 09:50 PM   #2
Pleasure Way would know and would likely be happy to help. probably a Manchester tank but call them to confirm.
Does your RV show the propane level inside the coach? If so, there would be wires leading from the gauge.
The other type I know of is a basic snap on.
To calibrate when replacing you need to fill the tank then use a magnet on the back of the gauge to rotate the gauge dial needle to Full then install the gauge.
Old 10-14-2018, 10:27 PM   #3
Thank you very much. I will contact Pleasureway tomorrow. And try
those snap on gages. They are cheap.
Best, Anna.
