Old 09-21-2014, 05:03 PM   #1
Default Marker Lights
I have a 1999 Rialta and am looking for marker light covers (amber and red). They are marked as LS315 and 118A/117R respectively. If anyone has any please contact me at andreolr@bajabb.com. Bob Andreoli
andreolr is offline   Reply With Quote
Old 09-22-2014, 08:51 AM   #2
You can find the red LS315 at http://www.schoolbuspartsco.co....._4_kd.html
The problem with the other ones is that you need 2-wire lights and they can be difficult to find. I got a pack of 1-wire from Harbor Freight and modified them by adding a ground wire.
Duane
TXPigeon is offline   Reply With Quote
Old 09-22-2014, 08:52 AM   #3
That should be http://www.schoolbuspartsco.com on page 4, upper right.
Duane
Old 03-05-2015, 02:31 PM   #4
Duane - I had the same problem re marker light. I ordered one from Winnebago Parts, but what I received was not what I need for my 1988 Itasca Phasar. How did you add a ground wire to the one you ordered from Harbor Freight?
russell777 is offline   Reply With Quote
Old 03-06-2015, 11:04 AM   #5
When you open up the housing, you'll see that the existing wire goes to one side of the bulb. On the other side of the bulb, there will be a bus bar (metal strip) connecting it to one of the mounting holes. To be safe, I cut this bar. Then I soldered a new wire to the bulb holder and ran it out with the original wire.
Duane
