Old 12-09-2018, 05:14 PM   #1
Default Dodge 1998 restoration after engine fire
Any parts or advice would be helpful
I have room for you to stay with your class
B in Naples Fl
File Type: jpg 089ABE75-DBC3-4E7E-A3E0-690F5CCD373C.jpg (220.7 KB, 42 views)
Raywinter is offline   Reply With Quote
Old 12-09-2018, 06:10 PM   #2
Engine fires are evil!
The big thing is how much other than the engine compartment is affected. If it is just under the hood, it really isn't all that bad to fix, just replace stuff.
If it melted things inside the firewall, under the dash, it gets way more difficult and expensive. The problems can be just from the heat of the fire, or because wires shorted and melted other wires in the cab before the burned off. Shorts can take out all the computers and other sensitive stuff.
You are correct to look for some experienced help and perhaps a donor van, as at this point you really don't know how bad it is.
Old 12-16-2018, 07:25 PM   #3
Join this group on FB, it's quite helpful.
https://www.facebook.com/groups/237452113644165/
ThunderAce is offline   Reply With Quote
Old 12-16-2018, 07:48 PM   #4
I have a 1997 RT with the Dodge piwer plant.
Do you know what caused the fire? Want to keep an eye on that in mine too.
By the way....I too painted mine all white.
With a little red and blue striping.
Kinda a stealthy look.
Eddie
Eraygunz is offline   Reply With Quote
Old 12-16-2018, 10:36 PM   #5
peppster66's Avatar
Wow, so sorry to see that, I really hope you can save it, the rest of the van looks in great shape. I have a 1997 , so I also am interested to hear what you think was the cause,, keep us updated if you can,,, take care,,,,
peppster66 is offline   Reply With Quote
Old 12-17-2018, 12:28 AM   #6
Is that a 1998 Dodge chassis or a 1997 chassis?
98LeisureTravelDodge is offline   Reply With Quote
Old 12-31-2018, 04:37 PM   #7
Looks like the later 1998.
henknoordermeer is offline   Reply With Quote
