Old 11-15-2016, 05:29 PM   #1
Exclamation Brrrrrr - need hot water heater!
I have a 1977 Dodge Xplorer 307 - 400 / 8 cylinder motor. She's just the Xplorer - not Xtravaganza or anything. I'm only the 3rd owner and she only has.... ready..... 42K miles! It was GIVEN to me by my mom and stepdad. I am about to be living in her (hopefully by this weekend). I just learned last night that the HOT WATER HEATER doesn't work! EEEK! So, I'm in search of one. I have the original manual (a God send but I don't have it with me right now. I will add the details of the hot water heater later today. Any/all suggestions vastly appreciated! I'm going to rehab her and keep her retro - but retro hippie, not retro Brady Bunch. Any suggestions on remodeling will also be appreciated!
UrbanGypsie is offline   Reply With Quote
Old 11-15-2016, 09:14 PM   #2
Propane-fired water heaters have been an RV fixture for decades. You shouldn't have a problem finding a replacement that should slip right in, if that's what you need.
Meanwhile: heat your water on the stove! (Only a problem when it comes to a shower.)
2015 RT CS with E-Trek
Old 11-16-2016, 05:59 AM   #3
Lightbulb Need a Motor Aid Heat Exchanger
I have figured out that I need a Motor Aid Heat Exchanger - Radiant Circulation or 115 volt AC electricity. *No mechanical parts.
Old 11-18-2016, 01:35 AM   #4
Looks like this is what you need. Suburban 5094A Electronic Ignition DSI with Electric and Motor Aid Heat Exchanger 6 Gallon Water Heater RV Parts
This is the most expensive RV water heater I have ever seen!
Old 11-18-2016, 05:27 AM   #5
Considering the rig is 40 years old, I'd go cheaper -- propane only. $100 less at that same source.
(assuming op's rig has propane!)
Old 11-18-2016, 03:31 PM   #6
PPL has it for $472
1977 dodge xplorer 307, hot water heater, remodel
