Old 08-28-2021, 07:00 PM   #1
Default AiLi Multi-function Panel Meter
Measure battery Voltage (V), Current (A), State of Charge (%), Remaining battery capacity (AH), Charge and discharge currents. More details and photos at: Multi-function Panel Meter Model AiLi US-EL-80V150A. Offers for the meter, shunt, extra cable and housing considered.
Jim
Jim86301 is offline   Reply With Quote
Old 08-28-2021, 07:36 PM   #2
Jim
Hard to decipher how it works for reset calibration and setting current for indicator light, or what it is. Without an auto reset function and proper float transition amps settings, you can't do just one calibration and then be good forever. Amp hours in don't equal amp hours out because of charge efficiency. That's for lead acid, lithium needs different settings for fully charged, usually voltage trigger.
Are you the same Jim as is listed on the linked website sheet?
