Old 02-23-2019, 06:51 PM   #1
Default 2010-2019 Chevrolet Express 10.5" W Eaton TRUTRAC Locker Axle Assembly
This axle was removed from a 2017 Chevrolet Express 3500 with less than 5000 miles. This axle is an American Axle 10.5" FREE floating design 3.54 ratio with a BRAND NEW EATON TRUTRAC HELICAL LOCKER installed by Ring & Pinion Shop in Warren MI. 8 lug on 165mm. I purchased 2 of these through a GM bid program I am in and was going to use to upgrade my RV and a friends. I went with a dually axle so no longer need.
Will fit all 2010-2019 Chevrolet Express and GMC Savana with GHO or GU6 Option codes (single rear wheel). Has JL4 anti lock brake option.
$1100 in Upgraded parts and labor: Eaton Trutrac locker posi unit, New Carrier Bearings and Gaskets, New Diff Cover, New Pinion Yoke changed to fit gas engine Express version vans. Would need yoke changed for diesel version vans.
This axle is stronger than the 9.5" axle
$1400.00
Pickup in SE Michigan or can ship freight.
valvegod is offline   Reply With Quote
Old 02-01-2021, 06:23 PM   #2
I am interested in one of your 10.5 diffs. If you still have one please let me know. I am the service manger at a local differential shop in Tucson AZ.
Thanks Diffdude
Diffdude is offline   Reply With Quote
Old 02-01-2021, 07:46 PM   #3
Hey DiffDude Welcome to the Forums,
That's an old ad- hopefully you'll get a response
Plenty of AZ members here
Cheers, Mike
Old 02-01-2021, 07:57 PM   #4
Sent you a message back with my phone and email.
Thanks,
Shaun
