Old 11-05-2017, 02:34 AM   #1
Default 2006 Pleasure Way Plateau TS For Sale
We recently purchased a larger motorhome and, with sadness, it's time to sell our Pleasure Way. We have owned our Pleasure Way for three years and for most of its life it has been stored under cover when not in use. We are mature owners, non-smokers and, like the original owner, have taken meticulous care of our beloved Plateau TS. This RV is in pristine condition, inside and out--you will be hard-pressed to find a better cared for motorhome. We have the original manuals for all appliances, all receipts, brochures and maintenance/service records for the entire history of the vehicle.
This motorhome is fully self-contained and very economical to operate--averages a documented 22 miles per gallon. Perfect for 2 people, easy to drive and parks in a regular parking space. This is a very hard to find unit and comes with many extras, such as two-100W roof-mounted solar panels, two newer Lifeline 220 Ahr AGM house batteries, a Trik-L-Start to maintain the chassis battery, Scan Gauge II to monitor engine performance in real time and much more--for further details, see "Recent Upgrades," below.
This van is a real head turner--don't consider it if you dislike strangers giving compliments on how great it looks. Seriously, this is not an exaggeration! SERIOUS INQUIRIES ONLY.
Offered at: $58,900
Contact: Ken at 360-825-0264 (a landline number--no texts!)
Location: Enumclaw, WA (about an hour from Seattle and Tacoma)
Highlights
• Length: 22 ft
• Odometer: 53,000 miles (Purchased from the original owner in 2014 with about 26k miles)
• Mercedes Benz/Dodge 2500 Sprinter chassis
• Mercedes Benz 2.7L 5-cylinder turbocharged diesel engine--very reliable and trouble-free engine and transmission. Does not use DEF, Diesel Exhaust Fluid.
• Averages a documented 22 miles per gallon (500 mile cruising range on ¾ of a tank @ 60 mph!)
• Sleeps 2
• Hard to find 20th Anniversary Edition with silver exterior and cherry interior cabinetry and paneling--see the pictures for details
• Mint Condition: everything works as it should--ready for your next adventure!
• Never used for towing
• GVWR: 8550lb
• Dry Weight: 6878lb
• Recent Service: Oil change with Mobil 1 229.5 spec synthetic oil and new oil, fuel, air and cabin filters--Good to go for another 10,000 to 15,000 miles!
RECENT UPGRADES (all in the last 1 to 2 years)
• Exterior propane quick-connect for BBQ, Fire Bowl, etc.
• New high efficiency LED lights for all interior lighting
• Two roof-mounted 100 watt solar panels by Grape Solar--provides energy independence when dry camping
• Trimetric SC-2030 solar charge controller (30 amp)
• Trimetric 2030RV battery monitor--takes away the guess work of the house batteries state of charge
• Two Lifeline 6V 220 amp-hour AGM maintenance-free GPL-4CT batteries (more than doubles the OEM house battery storage capacity)
• New 13,500 BTU Dometic Brisk Air II rooftop air conditioner
• Kenwood CD HD-Radio receiver with Bluetooth for hands-free calling and audio streaming, USB port, Pandora, iHeartRadio
• Pioneer speakers in the cab
• Newer Toyo Tires--in great condition with years of tread left
• New carbon monoxide and propane detectors
• Trik-l-start (automatically charges and maintains the engine's starting battery when parked for extended periods, ensuring reliable engine starting and maximizes battery life)
• Scan Gauge II (monitors engine performance in real time)
• 12 volt and USB charging outlets added in the coach for convenience
• New back-up camera (works in the dark too!)
• New Dorman Turbo-Resonator (no worries about the fault-prone OEM); works like a muffler to quiet the turbocharger
• New King Controls Jack amplified HD TV antenna--picks up over-the-air stations up to 50 miles away, sometimes further!
• Thinsulate and Reflectix insulation added above the cab headliner--much quieter and cooler cab!
• New 200 amp Cole-Hersee battery isolator solenoid
COACH SPECIFICATIONS:
• 2.5 kW ONAN propane generator with remote start switch (only 86 hours on generator)
• Dometic 3-way 4 cu ft refrigerator--runs on propane, 120 VAC or 12 VDC
• Dometic microwave oven
• 2-Burner propane stove with electronic ignition
• 16,000 BTU auto ignite furnace with thermostat
• Shurflo on demand pressurized water system
• 6 gal Suburban auto ignite propane water heater
• 13,500 BTU Dometic Brisk Air II roof-top air conditioner with optional heat strip--this unit is almost new with only a few hours on it; Replaced the OEM 11,000 BTU Dometic Penguin air conditioner
• LP detector, CO detector, smoke detector
• 5 lb fire extinguisher
• Monitor panel (monitors levels of house batteries, propane tank, gray and black water tanks)
• Flip up and slide out counter extensions
• Low profile fantastic Fan
• Cherry wood cabinetry with high quality hardware--superb craftsmanship!
• 120V/ 12V / 40 amp Progressive Dynamic 4-stage charger - converter with Charge Wizard
• Auxiliary battery disconnect
• Fresh water tank: 23 us gallon / 87 l
• Grey water tank: 24 us gallon / 91 l
• Black water tank: 12 us gallon / 45 l
• LP tank: 12 us gallon / 45 l / 50 lbs
• Interior standing height: 72"
• Aisle width: 27"
• Memory foam King bed size: 74" x 68" or twin-size beds on driver and passenger sides: 74" x 26" each
• Two newer maintenance free AGM Lifeline 220 AHr 6 volt deep cycle auxiliary batteries
• Driver and passenger front ultra-leather seats
• Swivel passenger seat
• Memory foam rear cushions
KITCHEN
• 4 cu ft Dometic 3-way fridge/freezer (propane, 120 and 12v)--works great, even in the hottest weather!
• Dometic build-in microwave oven
• 6-gal Suburban auto ignite water heater (propane)
• 2 burner propane stove with electronic ignition
• Overhead vent with Fantastic Fan with thermostat control
• Two slide out kitchen counter extensions
• Sink with hot and cold running water
• Spice and towel racks
• Paper towel rack
• Amazing amount of storage: wardrobe closet, several large cabinets, large deep drawers, large overhead cabinets
SLEEPING
• Power sofa converts to king sized memory foam bed (74" x 68") or 2 twin beds
• Comfortable memory foam
• Large overhead cabinet to store bedding and pillows
DINING
• Removable dining table
• Comfortably seats four adults
PRIVATE BATHROOM
• Thetford flush toilet
• Vanity with under sink storage cabinet and 3 drawers
• Medicine cabinet with mirror
• Shower with hot and cold running water
• Roof vent
• 3 towel bars
ENTERTAINMENT
• 17 inch LCD flat screen TV with CD / DVD / MP3 player with swing out cabinet
• HD Jack antenna with antenna amplifier (picks up those far away over the air HD TV stations)
• Premium sound system with 300 watt amplifier and 4 stereo speakers
• 300 watt inverter--converts 12VDC to 120 VAC to power the entertainment system off of the house batteries
• Exterior cable TV hook-up
• HD recorder/player with USB port for memory stick
SAFTEY
• 4-Wheel disc brakes with ABS
• Back-up camera with 5.5 inch color LCD monitor; Camera with IR lights to work in the dark DUAL AIRBAGS
• Power door locks, windows and mirrors
• Large power rear view mirrors
• Seat belt seating for 5
• Driver and passenger side airbags
CHASSIS SPECIFICATIONS:
• 8,550lb GVWR
• 2.7L 5-cylinder Mercedes Benz Turbocharged diesel engine
− Does NOT use DEF, diesel exhaust fluid--No expensive DEF emission system repairs to worry about!
− Does NOT require low-sulfur diesel fuel--No problem traveling in Mexico.
− 154 HP @ 3800 RPM
− 243 Ft/lb @ 1600-2400 RPM
• 3:72 Rear axle ratio
• 5-speed automatic transmission with touch shift
• 158 inch wheelbase
• Power door locks
• Chassis air conditioning (very cold and powerful!!)
• Cruise control
• Power windows
• Power side mirrors
• 4-wheel disc brakes with ABS
• Driver and passenger air bags
• Pioneer speakers
• Alloy wheels
• Fuel tank capacity 26 US gallon / 98L
• Rear Air Ride helper springs
• 5000 lbs towing capacity (but never used for towing)
• Auxiliary 12V and USB outlets
• Trailer Hitch with wiring
EXTERIOR FEATURES:
• 13 foot Fiamma awning in like new condition!
• Exterior shower
• Convenient utility hook-up center
• Frameless awning style windows
• External storage compartment on the rear passenger side
• King Controls Jack HD directional TV antenna with booster
• LED porch light
• Locking fresh water fill
• Sewer hose storage
• Rear under carriage full size spare tire
• Phone jack (but who uses these anymore?)
• 120V receptacle
• Fiberglass running boards
• Exterior height 9 feet 10 inches (including roof air conditioner)
• Exterior length 21 feet 11 inches
• Exterior width 6 feet 6 inches (without side mirrors)
Please note: The first three pics of the exterior are with the OEM low profile Dometic Penguin A/C (with silver-colored shroud) that were taken before it was replaced with the new Dometic Brisk Air II A/C (with the taller white shroud) and also before the two 100W solar panels were added.
File Type: jpg Driv Side - Rear_with old AC_Low Def.jpg (156.6 KB, 88 views)
File Type: jpg Bathroom Vanity Drawers and Cabinet.jpg (114.1 KB, 61 views)
File Type: jpg Roof-Solar Panels-King Jack Antenna-Brisk Air II A-C.jpg (145.0 KB, 91 views)
Namaste! is offline   Reply With Quote
Old 11-11-2017, 12:30 AM   #2
Very nice rig. Similar to my 06 Great West Van Mercedes. Got all of the extras that I’m doing to mine. Price is in the ballpark for a well built and well maintained unit...but I’m not in the market to buy another one right now!
Marley is offline   Reply With Quote
Old 11-11-2017, 04:38 PM   #3
Namaste, I hope your Plateau finds an appreciative new home. It's obviously a well-cared for rig. Great job listing all the amenities. If I hadn't found our LTV FreeSpirit last year, I'd seriously consider this rig.
2010 LTV Free Spirit
1989 VW Westfalia
NAZCamperVan is offline   Reply With Quote
Old 11-14-2017, 11:07 PM   #4
kkellerford's Avatar
Default What a beauty!
I'm in the market and this is everything I want and more.
kkellerford is offline   Reply With Quote
Old 11-15-2017, 01:07 AM   #5
Thanks for you interest in our PW, but it will likely be sold either tomorrow or possibly on Thursday to a local buyer. All the best in your search.
Old 11-15-2017, 11:17 PM   #6
FYI.... Sold our PW today for the asking price. Thanks for your interest and all the best!
Old 11-18-2017, 02:46 PM   #7
Our Pleasure Way has sold and I don't see a way to delete this (my) ad. Please help! Thanks.
Old 12-22-2018, 03:44 PM   #8
Namaste,
I know you sold this Pleasure-Way, but we have the exact same vehicle and are planning to make nearly identical upgrades. Were wondering if we could pick your brain on any tips or vendor suggestions. Did you do the solar addition yourself or have it done somewhere?
Many thanks,
Bradley
boondockage is offline   Reply With Quote
Old 03-01-2021, 03:39 PM   #9
Bradley, where are you in Florida?? I'm in Port Richey.
Sprinter lover is offline   Reply With Quote
airstream, coach house, leisure travel, roadtrek, sportsmobile
