Old 01-14-2007, 02:47 AM   #1
Default Amps used by common RV items
I'll start a list here of the amps used by common RV items. Some of this came from Wilton's site and I've change the amps after looking at owner manuals.
Item_____________________________Amps
Lighting (1156 Single bulb)___________1.3
Lighting (Led 1156 Replacement)______0.1
Lighting (Fluorescent)_______________1.4
Furnace__________________________2.8
Fantastic Fan Low__________________1.86
Fantastic Fan Medium_______________2.29
Fantastic Fan High__________________3
Stove Hood Fan____________________2.2
Microwave on inverter_______________90
CO Detector_______________________0.06
LP Detector________________________0.086
Water Pump_______________________3.8
Water Heater______________________0.75
TV_______________________________4
DVD_____________________________2
Please add to and/or correct this list as needed.
Old 01-14-2007, 02:53 AM   #2
Default
Special note re: newer Roadtreks with Tripp Lite inverter
If you have the factory installed Tripp Lite inverter and if it was left with the switch on "Auto" you would use 30 amps in 24 hours!
Inverter 24 hrs @ 1.25 = 30 amps
On the Tripp Lite inverter there is a 3 position switch. The choices are: Charge only, Off or Auto (inverter on + charging if plugged in). Remember to set it to Charge only when you are not using the inverter.
If you have a remote switch you have 2 choices: Charge only or Auto (inverter on + charging if plugged in). You can buy a remote switch to make it easier to switch from Auto to Charge only. Here's a link to making your own switch:
Roadtrek - Tripp Lite Inverter/Charger remote switch
Old 01-14-2007, 04:14 AM   #3
g1g
Default
I never knew a single 1156 bulb used that much power. Never saw any specs on them
Old 01-14-2007, 04:25 AM   #4
Default
I just googled 1156 lamp amps and the first two sites I checked show 2.1 amps for a 1156 bulb!
