We have a SurFlo 4008 (3.0gpm, 45psi). I'm ok with the flow rate and pressure... a bit higher wouldn't be bad, but the damn thing is noisy as heck.
We've also got a slow internal leak in the system somewhere. It's either in the pump or in the Fill/City-Water valve. When we connect to city water for normal use the fresh water tank starts refilling very slowly until it overflows.
So, as long as I'm gutting the plumbing system, I may as well replace the pump with a decent one.
I don't need it to be huge, but I'd like something quieter... and based on what I've seen elsewhere, Winnebago generally installed really crappy hardware in their rigs, so it's likely a junk pump anyway.
Any advice? what's a good brand/model to look at for a replacement?
Many thanks!
Many thanks!
