Our Galleria had a Firefly issue and were just two years into ownership. I started noticing commination issues between iPhone APP and Firefly, as I would sit inside the van and check overall operations and the signal via "Bluetooth" which looked like it was dropping.
I called Firefly and give them the VIN Number and learned I needed to replace the Vega Touch Eclipse Module. Thank goodness i did as it was still under warranty. The new module arrived and the old was located inside the control panel and held by two small screws. I turned off the power by placing the VAN in STOAGE mode. The change was very simple.
Only two wires plugged into it, and I unplugged and replaced them into the new module. Never knew how bad the old module was, until the new one was added operating a pick performance. No signal drops and clear easy to read screens.
