Mike-ClassB
Hi everyone,
I have been considering an upgrade to my converter/charger in my '02 190P for a while now. I want to
replace or upgrade the original charger to a 3 stage, and add an inverter function to also feed the existing
AC receptacles that are "live" when plugged into shore power or when I run the Onan. I also figure if I'm going to
do all that, maybe it's time to consider/examine a solar powered coach battery maintenance system as well.
I have 2 problems (some would say, that's not entirely accurate :wink: ).
The first one is I don't feel comfortable DIYing something like this, and even if I did, I don't have anywhere
warm/dry/free to do it. I could probably wait a few months, or try to find a rental shop that can handle
my van, but then time becomes $$$, if I take my time, it'll cost more $$$. I can be as careful as the next guy
when it comes to electrical safety, and I think I have enough common sense not to fry myself, but I'm not as
certain about the van, and a mistake could be very costly.
My second problem is that I don't seem to be getting anywhere locally here in Ontario, looking for a reliable shop
to do this type of work. There are plenty of places that sell the hardware, but no one with the knowledge
about the hardware, installs it, and no one who does installs seems to have sufficient knowledge of the hardware
to make me feel like they know what they're talking about when they start recommending hardware.
I've emailed and actually visited one or two places to try to get an idea of what skill level they have, but so far no
one has a turn key solution that isn't going to cost more than what the van is worth. I'll spend a bit more to
get good workmanship, but at some point cost overrules everything else.
I think I could reasonably live with a 1000-2000W modified sine wave inverter, unless there was a fabulous deal
on a pure sine wave model. A 30A charge circuit is probably sufficient, as we move around a fair bit, and it would
probably be more than sufficient to replenish the batteries. Everything else, I have no particular brand preferences
or loyalties beyond price/performance. I'd like to spend around $2000 all in. I was looking into the Xantrex
Freedom HF 1800W inverter/charger model, as I believe it would handle my power requirements, and I could
probably get one for around $600 in the USA. The rest of the money would be for the labor and any additional
parts and possibly a small solar top up system, one decent 100W 4-5A roof panel and charge controller? I don't know
what they cost, or whether the numbers I'm throwing out are reasonable for this sort of project. If it came down
to cost as to which part of the project I'd want to do first, it would be to get the charger/inverter first, and then
maybe add the solar top up system at a later date, unless there were significant advantages to doing it all at once.
So, if you were going to get some custom electrical work done like what I've described, and you aren't a DIY
wizard, where would you go for RV related electrical knowledge and reliable installation?
Assume I'm able to travel to the place you might recommend, within a few months, or later this year.
I've seen AM Solar in OR mentioned on here, as well as Outside Supply in LA. I've emailed them with my
upgrade/custom work questions. A stop/side trip on our next tour to get an estimate done on the RV is
never out of the question.
Maybe someone has had good luck or experience with their local Camping World, or some other nearby big box RV place?
Maybe your local Roadtrek dealership or authorized Roadtrek service center guys seem to know what they're
doing? Or, you know a guy who does this in his spare time, and really knows this stuff? To any of the dealers on here,
do you have any thoughts on my upgrade questions? I'm not that far from Ohio, or Pennsylvania. We love cross border shopping. :thumbup:
Opinions, ideas, suggestions, even DIY or partial DIY suggestions are all welcome. :think:
