Roadtrek Adventurer RS Width
ovsa
Feb 19, 2021
57
calgary
Hello.
All the data I could find on the width of the 2014 Roadtrek Adventure RS shows the width as 6'8" without mirrors. Not sure what good that measurement is.
I wanted to built a carport and I have limited room. Anyone know how wide these units are with the mirrors out? Do the mirrors fold-in on this model/year? What would be the dimensions with the mirrors folded in if they do?
I haven't received the vehicle yet...just looking ahead.
Thanks
Overall width not including mirrors is industry standard for all motor vehicles under DOT and state regulations, so that’s what’s always given. 80” is a break point on width: extra clearance lights are required over 80”.
Hopefully someone will be along shortly with the number you need. On my Chevy Roadtrek the mirrors fold quite close.The widest part for storage parking is actually the rocker panel storage pods.
The mirrors measure out to out a little over 95" on my drawings. I would round that up to 96" which is 8 ft. Folded in I doubt you could get under 7 ft. More likely 7'-2".
Hi. I have a 2013 Roadtrek Agile and both the mirrors do fold. I’m not home now to measure with the mirrors folded but can check later. Enjoy!
Linda
I plug our rig into shore power when stored - a Roadtrek 190 - and need the lower storage compartment cracked ajar for the cable. This is an easy spot to crunch on ours when entering or exiting tight storage. Padding on the inside edges of the enclosure supports might be worth considering - ours are concrete so gotta pad them.
BJ
OVSA, considering that you only have 106" maximum, even at 80" vehicle width you won't be able to open any swing door. Could you perhaps strategically place a door opening on the garage sidewalls adjacent to your driver side door?
