Replacement for 2003 Rialta QD monitor panel?
stereorowe
Aug 22, 2020
4
Washington
I need to find a replacement for the monitor panel in my 2003 QD. The one I have is an LA1023 which hasn't been produced for many years. Mine has 3 switches (both fresh water and shower drain pumps plus the generator start/stop toggle - this latter is not used as the generator was removed) which also seems unusual. The circuit board is blown (hot wire got loose and fried the board) so if I could find a direct replacement, that would be fantastic. Otherwise, if I can find an adequate replacement with enough wiring diagram information for wiring it up - that also could be the solution. And yes, I know you can track the tanks levels manually, but I'd like a panel to provide some information.
