Recaulking
silverchris
Jun 12, 2016
18
Ontario
Hi All,
The seam where the roof meets the body on my 2001 Leisure Travel Freedom, is starting to feel a bit hard and crack.
What is the recommended caulk/process to remove and replace the caulking?
Sorry, I should have specified it was fiberglass to fiberglass
Right around the white line above the window in this photo
You can probably use Dicor, but your best bet would be to go to a few rv dealers and ask them. They'll give you a few suggestions from what they sell.
Ended up being recommend Geocel Proflex RV.
It seems to stick really well, and remain flexible so far. It also seems to bond to itself well, which is good if you put it on to thin in an area, and presumably down the road will make life easier if it gets ripped off or cut.
Only issue is it has a VERY short time where it is workable, which makes getting a smooth finish difficult.
Leisure Travel Van
Hi, it looks like you have the same 2002 LTV I have. I had the same issue but mine was leaking and ended up having to go into the seam from inside and cut out a bunch of rust. Hope you caught it before it leaked. This is what I used and it working great.
Eternabond Eternacaulk White High Performance Sealant
by Eternacaulk by Eternabond
Link: http://a.co/iMgRuQS
On another subject about you LTV maybe you can help me out. When I bought my van the bumper cap that covers the sewage storage area was missing. I made a new one but since I never saw it in place I couldn't figure out how the latch worked. Any chance you can snap a picture of yours in the open position and post it here.
Thanks
Don
Next time I am over were it is stored, I can grab you a photo of how mine is, which I believe is factory :)
Will likely be sometime this weekend
How did you end up removing the old caulk?
I might have to do the same between the body and coach of my RT.
Most of it was removed using either a plastic scraper, razor scraper, or a pick, as it was silicone and didn't respond well to chemicals. It was a bit of a pain!
Thanks
Don
Hopefully this helps, Imgur: The most awesome images on the Internet
Let me know if you want any detail shots of anything!
