Just bought a 2011 Airstream Avenue. Thinking there should be a separate Avenue forum due to the large number of owners out there. Lol. Anyway, after going through it for a few days, I thought I’d list what I’ve found. Not sure if anyone will be interested, but, here goes.
The “bad”:
House batteries were shot. I expected this. Bought a cheap marine battery to get by while inspecting everything.
Driver and passenger seat swivel mechanism will not lock in the forward facing/driving position. Yikes! Good news – there is a recall on this. Awaiting info to get this repaired. Both seats each have one small split on the bottom seat cushion.
The microwave door latch is broken. Will look into replacing the microwave.
Tires are 5 years old. Off brand, but appear to be in good condition – no checking/cracking.
The clear-coat on the roof is shot – peeling all around.
The generator runs well for about 20 minutes, then sputters and dies. I checked the oil, which was a tad low. Those of you who own an Avenue, do you LOVE the access to the generator?! I added oil, didn’t rectify the problem. I suspect the fuel pump or fuel filter. Good news is the previous owner just had a new carb installed.
The freshwater tank drain had been broken off. The tank doesn’t appear to be damaged. Bought a PVC plug, tank now holds water - no apparent leaks. (Thanks to rowiebowie for assistance with this.)
Toilet supply water connection leaks. Awaiting replacement parts.
No macerator. Apparently it was removed and replaced with a regular 3” connection.
The Coleman A/C fan only runs on high speed. Also blows out pieces of foam/insulation.
The Maxxfan lift mechanism is broken. Awaiting parts.
Front “air dam” is cracked. Not very noticeable.
One outside storage lock needs to be replaced.
Needs a good interior cleaning.
The “good”:
Engine and transmission appear to be in good mechanical condition. Runs well, drives well. No rust. 83,000 miles.
The previous owner said that the power awning did not work. It opened a few inches, and, after I gave it some gentle “percussive therapy”, it works just fine, for now.
After the above mentioned freshwater drain replacement, I haven’t found any leaks in the water system.
That seems like a long list. However - so far, repairs don’t look too expensive (other than the clear-coat…..)
The “bad”:
The “good”:
