separate out any "Ford" problems and look them up on a Ford Van forum- if there are 1000 Fords of your vintage on the RV forums, there are a million on the Ford Forums and mechanical or chassis issues will be commonly solved there- like power windows
"wires under the hood" probably RV stuff-
many RV's have the alternator output to a "battery isolator" which connects to the chassis battery under the hood----AND to the battery(ies) for the RV part- the RV batteries are isolated when the motor is not running to keep from running down the chassis battery while camped
I have trouble with pics too, they seem to go better as a cut and paste than an attachment. you'll probably need to struggle through this to illustrate concerns/issues
as above, plenty of the Intervecs around and a well respected brand
if you have a dometic fridge or an Onan genny, the manuals are available online
cheers, Mike
