Cubey
- Joined
- Sep 4, 2012
- Posts
- 41
Okay... here's the deal. My 1978 Dodge B300 chassis Class B probably has the original shocks on the rear. They have a helper spring attached to them. I bought a pair of Monroe Magnum-RV shocks to have installed figuring maybe the old ones with helpers weren't made as well. After all, technology has progressed just a bit since 1978. Maybe shocks are made better now and don't need a helper spring for heavy duty applications.
So... I took the van and shocks to a mechanic who stated that they were not heavy duty enough to support the rear end of my motorhome. His reasons were that they would immediately sag and would quickly wear out or blow out under that much weight. He did all but refuse to install them but he really acted like he really didn't want to do it.
I opted to return the shocks and paid no labor. I didn't want to risk him somehow being RIGHT (I paid $182 for the pair of shocks!) since it costs me nothing to wait a little longer. (In fact it might save me money since I can order the parts online for a lot less money). Also, when a shop makes strange claims like that, it makes me nervous about their mechanical ability. Maybe he's 100% right, so I decided to put it off until I get a second opinion.
There is only one kind of shock that includes helper springs on them, and that's Gabriel Load-Carrier. They look pretty wimpy though. Plus it seems they come in pairs so you can't just buy one and replace it if one goes bad.
It turns out you can buy add-on springs for shocks that even specifically say "for older model vehicles". I dug them up on O'Reilly's website, but Amazon also sells them for about $12 less. They clamp on to your choice of shocks for added weight capacity to the shock, Here is what the kit looks like:
The only thing heavier duty out there are Bilstein 4600 series which ALSO lacks helper springs.. but at least they ARE heavy duty rated like the Monroe Magnum-RVs are. The Gabriel Load-Carriers say nothing about being heavy duty.
Those of you with Dodge 1 ton Class B's, especially older ones... what shocks have you installed and had good luck with? Have you had any problems with the Monroe Magnum-RV shocks? Or even Bilsteins? Did you need to add helper springs to the shocks?
I will also be checking in at a spring shop when I get to Tucson early next week. They work on everything from pick-ups to semis and everything in between, including RVs. Maybe they can offer some advice in addition to what you guys have to say.
They also have a weigh scale so I can get it weighed as well while I'm there so I'll know just how heavy this thing is fully loaded like I use it. I full time in it so it's pretty well loaded up. I drive with the fresh/grey water capacity of 22 gallons total due to being off the grid a lot. Plus my water heater and recirculating toilet which is about another 8-10 gallons.
