It is possible that a campground (or perhaps a friend's driveway) will not have a 30 amp receptable available for your use.
You can purchase a 15 amp to 30 amp adapter and connect to an ordinary 15 amp household outlet.
Be aware that in those situations, you will have limited power compared to a 30 amp circuit. You will be able to run a single
large appliance at a time; you may need to turn off your air conditioner if you want to use the microwave, for example.
If you exceed the current capacity of the receptacle you may pop the breakers in the pedestal. If this happens, turn off some
appliances and reset the breaker.
It is also possible that you will find a 50 amp receptacle. Again, you can purchase a 50 amp to 30 amp adapter. In this case
your power should not be limited as you will have the full 30 amps available. Although you are connected to a 50 amp
service, you can only draw 30 amp; there is no advantage to connecting to a 50 amp service if a 30 amp service is available
