hbn7hj
Objectives:
1 Two totally separate power and charging systems. Lead Acid and Lithium. Lead acid is slow to charge and difficult to use the full capacity but works very well below freezing. Lithium can use more of the capacity, charges rapidly, but does not handle temperature extremes well.
2 Test whether a fully charged lithium battery connected to a battery to battery charger can charge a lead acid battery to 100%, overnight, after being brought to 80% charge by generator.
3.Determine how the two different batteries can be joined together to power the RV.
It is not necessary to respond to this thread to keep it going. Comments welcome. I will add progress information as I have it.
Components:
60 amp Lithium battery charger
Progressive Dynamics PD9160AVL
40 amp battery charger for lead acid batteries
Xantrex Smart Charger 2
Battery Switch
Blue Sea Systems 350 amp 9100E
Battery
BattleBorn 100 ah Lithium with BMS located inside the coach
for temperature stability. No battery heaters needed
2 Trojan T-105 flooded lead acid 6 volt 225 ah 5 years old.
Battery Monitor
Bogart Engineering TM-2030 Boondocker (lithium)
100 amp shunt.
Bogart Engineering TM-2025 (lead acid)
100 amp shunt.
Battery Tray
Attwood Marine Series 29/31
Battery to Battery charger
Kisae Technology ABSO DC to DC Battery charger
DMT1230 12 volt 30 amp
50 amp toggle switch from Backwoods Solar.
Generators
4kw Onan Microquiet
1kw Honda EU1000i on propane.
Solar
200 watts. Not a major player in this excercise
Components:
Battery Switch
Battery
Battery Monitor
100 amp shunt.
100 amp shunt.
Battery Tray
Generators
4kw Onan Microquiet
Solar
