SteveJ-ClassB
Steve J,
Does this come with the temperature sensor?
Yes, and IIRC, it's water proof.
Steve J,
The Inkbird is one of the controllers that I have heard of being used to put electronic control on the compressor frigs, also. Most have had good luck with them in those applications.
I have a very similar 12v unit on the control system I built for our HRV ventilator in our house to replace the garbage touch screen version the manufacturer provided that failed every few weeks. I am using on a defrost circuit in the HRV. I do wonder a bit about the <3 watt power use spec, though, (ours is 2W) as they have a fairly large LED three number display on 24/7 with no way to time it out. I have not measured our use on the HRV because it runs on the HRV power supply so is essentially on house power. But even 3 watts is about 6ah per day. The other essentials running like detectors and monitors I put at 10ah earlier in a post may or may not be high depending on what you have, so still 15ah or so before you actually use any for other things.
Does your 20-25ah per day use include the solar running and supplying some power? Solar can really mess up trying to find out how much power you really use because the solar controller output totalizers are often not very accurate and don't take into account charge efficiency, and the normal battery monitor subtracts off what goes back into the battery or is used in the van from you daily AH gain. The power that goes back in or is used in the van is lost from the monitor, also.
There is one thing about the power use in the gas frigs these days that is good compared to a compressor frig, and it is that a gas frig usage doesn't vary nearly as much with run time and temperatures when compared to a compressor frig, so the gas frig is easier to estimate total use for figuring out power needs.
I didn't get the Inkbird to save power. I bought it cuz I got real tired of having to babysit the Dometic due to crappy temperature control. It worked perfectly for that.
That's why I would want it for my new Dometic RM2554, as the temperature control is very flaky.
I just turned on the 2354 refrigerator. The total amp draw with flame burning is .25 amps. That is 250 milliamps. It is dark out so no solar. I am surprised. Will do further tests tomorrow to verify. Seems a bit low but I can’t find an error.
FWIW - When studying the feasibility of replacing our RM2554 with a NovaKool AC/DC, I did a lot of electrical analysis. Our RM2554 in propane mode drew 0.52 amps.I've been toying for some time with replacing my Dometic 2310 3-way fridge with something.......it's begining to not respond to the thermostat control and doesn't seem to make a difference if it's on max or min temp. So the logical 3-way replacement seems to be the 2354 which is the same size.
BUT, from what I can understand from on-line comments, it takes 1.3A constantly just to run the circuit board. If that's the case, it seems like a small jump to a compressor fridge of similar size which appears to be using 2.2A when running.........and it wouldn't run all the time.
Does anyone know if my stats on the 2354 are accurate?
If so, I'd have to increase my battery capacity either way.
Thanks in advance
Glenn
