tex4judy
Hello - am looking for the guys who know what the electrons are actually doing. Am converting an empty cargo van into a Class B RV. Running 4/0 cables from the secondary alternator (Nations 12 VDC 280 Amps) to the house battery buss bars. Batteries are Lithionics 2 X 195 Ah batteries. Also running a 10 gauge wire from a keyed ignition source to the internal battery monitoring system integral to the batteries and then up to the Balmar Voltage Regulator. If I run the 10 gauge wire in the same plastic conduit as the 4/0 gauge wire, is there a disruptive field from the larger wire that will "interrupt" the signals to the voltage regulator in the smaller wire? Any feedback will be helpful. Thanks
