Stevemo-ClassB
I parked my van for the winter with a problem that is common on the 2003+ Chevy chassis. The front end shakes when you press the brakes. From my experience it can be very violent and make the vehicle dangerous so I need to fix it when I pull the van out of storage in the spring.
Who else here has had this problem and also worked through it?
This is a 2004 Roadtrek 190P 3500 with about 100k miles on it. I changed all of the brake hoses, had it aligned, checked the suspension except for a few parts, and the brakes are in very good condition. I have also determined that cupped wheels are a symptom of the problem and not the cause of the problem. Rotating your tires will help for a while but it will just munch up the fresh tires and get bad again.
I'm pretty sure the issue is related to the steering box, pitman arm, idler arm, or maybe even the splines on the steering box that join to the pitman arm.
This video sort of shows the shaking of the wheel. If you ever run into this park immediately. You'll be dead if you try to drive in the mountains with this issue as you have to pick between steering and breaking as they won't work together.
