Margaret Alexander
Hello,
Has anyone replaced the house batteries with lithium batteries, in the 2017 Carado Banff?
After six years of working with it I still think the dual battery system is the better way to go. Keep the original lead acid system as is, inside the coach add the lithium batteries, their special charging systems, and a switch to switch between the two.
The advantage is the outside battery compartment is still being used, the interface with the alternator is untouched, and the generator starts from the lead acid battery. The lithiums are inside where it is warm with their special chargers. You can also charge the lead acid batteries from the lithiums which reduces generator run time.
Just an opinion.
