markopolo-ClassB
I recently added a new smart battery isolator ( http://www.classbforum.com/phpBB2/viewtopic.php?f=12&t=3576 ) using short runs of 4 gauge wire and for good measure I added an additional body ground ( http://www.classbforum.com/phpBB2/viewtopic.php?f=9&t=3573#p26314 ).
It warmed up to a bit above freezing today so decided to run the microwave oven in my van off the alternator to see if those two modifications gave any noticeable improvement in maintaining voltage etc.
A previous test ( http://www.classbforum.com/phpBB2/viewtopic.php?f=9&t=2668#p15768 ) a year and a half ago had these results:
I combined all battery banks using the old isolator, new smart isolator and manual marine type switch. The van was running at a cold idle around 800 rpm. Voltage displayed on the inverter was 14.7v. I ran the microwave oven on full power for 20 seconds and the voltage only dropped to 13.9v. So I did the test again with the same results but this time listening to the engine and I could hear the change in engine sound as soon as I started the microwave oven.
The third test was at 1,070 RPM and it produced the same results but with no change in engine sound. 13.9v, 910 watts at the inverter. 910W divided by 13.9V = 65 Amps. Immediate recovery of voltage to 14.7v as soon as the microwave oven stopped.
In the previous test a year and a half ago the voltage dropped to 12.9v. Booster predicted that there could be some wire size or isolator drop issues in my setup. This is with the stock CS144 124 amp alternator - probably 18 years old. I think the 1 volt gain is a big improvement.
Do you think the 14.7 volts is a problem or could it have been because the van and alternator were really cold - I didn't even warm it up for the test. All 4 batteries were fully charged - been plugged in all winter.
The test was to run the microwave with the engine running at the three different idle speeds to see the affect on voltage. I combined the 2 house batteries, the 2 chassis batteries (4 batteries total) and the alternator for the test.
The voltage quickly dropped to 12.9 volts at each RPM setting. Each time I tested I ran the microwave for 20 seconds and I tested it 2 or 3 times at each RPM setting. The voltage recovered right away but was a little lower after each test. From 14.4v at the beginning down to 14v by the end.
