The floor between the twin beds in my unit has developed an irritating squeak on the driver side next to the storage drawer under that bed. Does any owner of a Dodge RT know what's under the carpet? Is it metal? Or did RT overlay plywood and glue the carpet to that? I don't want to drive a screw into the area until I know what's underneath.
From underneath the unit looking up at the floor from the bottom side, the area in question is just behind the fiberglass "pan" the manuf put in to accommodate the shower (which we never use). It is obvious where the original metal floor of the original van was cut to insert the fiberglass area. Inside the unit this creates a step up to the bedding area. I will attach a couple of photos to clarify these two paragraphs (I hope). Again, what I need to know (hopefully without tearing up the floor) is what will I be driving a screw into if I try to tighten down that squeaking floor? Any knowledgeable help is appreciated. In the old days, a call to RT Service Dept would have the answer. But, alas, those days are gone.
Both photos should be rotated 90 deg to the right. I'm pointing to the step up area in the one, and the squeak is where you step. The other photo is underneath the unit where metal floor was cut and the fiberglass "pan" installed.
