red wire on the holding tank
peanutmydog
Member
Joined
Nov 29, 2022
Posts
20
i notice my wires from the holding tank hanging down, so i crawed under there and all the wires still on the holding tank except the red wire,,does this wire suppose to hook up with one of the wires on the holding tank, if so which one?
I believe there are four wires attached to four metal studs on the side of the tank. We could look up which wire goes to which stud, but if only one wire is hanging and one stud is bare, you have your answer. You need to get those wires hung higher up and out of the way, so they don't get caught on road crud, curbs, grass/branches/dirt in a campsite, etc.
Bill
correct there are four metal studs on the tank the one that is loose i think goes to the end closer to the drainage, i have to connect it to the hot wire i sent a picture of underneath
  • IMG_0813.HEIC
Here's how it's wired on my '24 2518.
I assume each wire is to measure F, 2/3, 1/3, E on the monitor.
New posts
Top Bottom
