As more information has been coming in on new springs, shocks, wheels, tires, etc, you would think things would get clearer, but it seems to be going the other way. Harsh, not harsh, porpoise, no porpoise, springs fit, springs don't fit, shocks too short, shocks not too short, Tufftruk good, Tufftruk bad, Erb good, Erb bad. No real consensus on much of anything.
I was doing the bi-annual service on DW's CRV, oil, trans fluid, coolant, brake fluid, etc, so I had some time while things were draining, cooling etc. The Roadtrek is high enough for me to get under without jacking it up, so I crawled under to do some measurements. First I used a plumb bob to locate the lower control arm pivots on the floor, then the spring/shock centerline, and then the middle of the tire. Measured out to be 8" from the pivots axis to the spring/shock, and 20" from the pivot axis to the tire center. That means the spring and shock move 8/20 (40%) as much as the wheel. I then marked the shock at the bottom of the dust boot, so I could tell where it was in it's travel when loaded, after removing it. I took the shock out and checked how much travel was in each direction from the mark, which is at normal, light load height. It had only .4" in the extension direction, and nearly 4" in the compression direction. The .4" extension gives 1" at the wheel, which is about half of what I have normally heard is the proper droop at the wheel of 2".
At that point, I started to try to determine how much droop I could realistically have before the upper control arm hard stop hit the frame, metal to metal. I measured the wheelwell height at rest (37") and the camber of the tire (-.5*) and then lifted the van by the crossmember frame on the same side of the van in increments making the same measurements and also watching the gap close on the hardstop. Here is how the numbers came out:
37" / -.25* / gap at over 3/4"
38" / -1.5* / gap about 9/16"
39" / -3.5* / gap about 5/16"
40" / -5* / gap about 1/8"
40.5" / -- / upper arm on stop
From this it would appear that the most droop you would possibly be able to have would be 3", and that would put you awfully close to the stop, especially since the shock is in rubber and could possibly move further down if it dropped quickly. I already had 1" of droop, so if I wanted to go to 2", and stay about 5/16" off the stop, I would need the shock to be .4" longer, which would double the amount of droop. There was not enough thread to get .4", but 4 washers got me .320", and I could still get the nut tight enough to get to the locking section with one thread showing above the nut. After it was back in, I measured about 5/6" to the stop. Pretty close to what was predicted.
I didn't have a chance to take it for a ride to see if it makes any noticeable difference, but I am not expecting anything major, as I had not noticed the shock topping out in the past. We will see what happens in reality.
While it does appear that, at least in our case, a little more droop may be a good thing, and certainly doesn't hurt much, although the camber change does start to get pretty big, and seems to be the wrong way compared to what I thought it would be (I thought it would go to the positive).
The actual numbers also point out, if correct, that the posts wanting 2" longer shocks would be way, way, too much longer. Even 2" more droop at the wheel is possible, but getting very close to hitting the stops. You would wind up with more droop than compression travel as you would lose 1/2 your compression travel. It would also make contacting the hard stop on the upper control arm an almost certainty, if you hit a dip big enough. One wheel bumps would be much less of an issue, as the very large front swaybar would hold the wheel up a lot.
IMO, for our dimensions, a shock of .4-.5" longer would be the best. That would give 2-2.25" droop, which is right where folks say it should be, and it would still keep you off the hard stops. 3/4" longer would be getting you very near the stops, but give you another 3/4" droop to nearly 3".
It would be interesting to see if Bilstein makes this shock with a longer rod, so you could use a couple more washers. Even 3/16" longer would be enough to get you to 2+" of droop. (total of .480" in washers).
If folks had more overhang weight in the rear than we have, they may be lighter in the front and more likely to top out the shocks. That might also explain some of the porpoising issues. Large overhung weight, airbags up to support that weight, lighter front weight because of it, might give a rotation around the rear axle that would feel like front end bouncing.
Interesting stuff, but I still don't know what it all means or why the results are so different for folks.
