Old 02-01-2007, 01:20 AM   #1
Default How & Fay Gregg's Roadtrek and Customization
How & Fay Gregg's 1995 Roadtrek 190 Versatile Class B Van Motorhome
Here's another great page from their website:
http://mysite.verizon.net/howgregg/page3.htm
Some of their customizations are:
Silverware Drawer Divider - Fabricated thin divider for use in rear galley drawer.
Console and Caddy - Fabricated wood table with CB mount installed on underside on front console.
Clothesline Rack - Fabricated front bumber hook-over rack with 3 lines. Nests flat for storage.
Seat Drawers - Fabricated rear facing pull-out wood drawers, installed under driver and passenger front seat.
Toaster Oven Broiler - Commercial Black and decker with under cabinet mount, fabricated bracket with shelf, mounted over driver side rear seat.
Under Bed Drawers - Fabricated wood frame with two cross supports and longitudinal rails each side on underside for hanging wood sliding drawers, one accessable from inside front and other accessable from outside rear. Takes the place of table top as permanent bed support; air gaps left on sides and bottom for heater output.
Trash Bin Holder - Fabricated wire coat hanger shaped to go around plastic trash can with hooks in rear to hang on hanging locker towel bar; installed high enough to clear bed when door opens.
Towel Bar/Privacy Panel - Fabricated 4 rod wood unit with masonite panel for storing bath towels in hanging locker and as separator between toilet and hanging locker.
