engnrsrule
Senior Member
Gas Absorption performance mods
I have a Dometic 3 way fridge in a 2006 Roadtrek Adventurous RS. I have been following this thread to help troubleshoot what I thought was poor performance on propane. I discovered it was actually NON-performance on propane, caused by the thermistor wire being slightly unplugged from the control module. fixed that and back in business.
However the good info here inspired me to add the wireless thermometer, which is great, and to add fan cooling to the rear of the refrigerator compartment.
I used two arctic F9 Silent fans, mounted to the removable grill, and wired to a SPDT switch allowing me to select manual on or thermostatically controlled operation (with an off position as well). The fans have very low draw. I added a baffle to direct most of the rising air into the cooling fins. I selected an adjustable thermostatic switch (set "on" from 90 to 130), as I felt like I would need to adjust or tune for varying conditions.
The two fans draw less than 1/2 amp total, and are very quiet. They do not move a lot of air, but they do produce a positive draft bottom to top through the fins which will certainly help.
The fan mod and baffle installation cost about $36. The key parts I used were:
- AcuRite 00986M Refrigerator/Freezer Wireless Digital Thermometer $20
- ARCTIC F9 Silent, 92 mm Fans with Standard Case (2) $6 each
- NTE Electronics 54-240W Waterproof Illuminated Rocker Switch, SPDT $8
- Emerson 3F05-1 Adjustable Snap Disc Fan Control $12
Pictures show the baffle in place, the interior switch location (in the vented trim around the microwave), the thermostat switch located above the cooling fins, and the fans. I used connector plugs to facilitate easy disconnection if the fridge ever had to come out, or to remove the grill. I put tabs on the thermostat to hold it against the fins and put a nylon tie to keep it in place.
Feel free to respond if you have any questions.
