Chevy Suspension Upgrade Complete
The springs that had bowing issues were test ones that were made at lower springrate and longer freelength than the Moog 81004 or some of the other stock length springs. Our early Tufftruck springs are essentially the same as the 81004 and have been in for something like 7 years without issue.
I don't think anyone has had bowing issues with the stock length and 1.03 or 1.06" diameter wire, which are what essentially everyone has, except for a few Erb springs that are 1" wire and about 1/4" longer than stock.
The 81004, Airlift, Bilstein combination is catching on and given very good results for quite a few people now.
Booster, you probably discussed this at lenght in Photog's thread, but could you give me (us) the reason(s) the Moog 81004 would lift and hopefully smoothe the ride of our rigs, replacing your original Tuftruc 1617 that are no longer available ?
I compared spring rate, free length and installed height between the OEM, 1617 and 81004 and it seems that the 81004 specs are much closer to the OEM than the 1617 which seems to be stiffer.
Just cant seem to get the courage to order before I am certain they will do the job up front.
Thanks
Thanks
Even if the details were in Photog's thread, and thus very hard to find, some things have changed since then anyway. The idea behind it all is still the same, however.
We likely had the very first set of the 1617 springs that Tufftruck sent to the US, and it appears that ours were not what the specs at the time stated. The spring shop and I did not notice that they were made of smaller wire size than the 1617 spec called out, at 1.03" diameter wire instead of 1.06" diameter wire. Later 1617 springs that others got shortly after ours were of 1.06" and stiffer, with some complaining of too stiff and others not. The current 1617 is different again, so can't compare, it appears.
As it turns out, the 81004 spring is also made with 1.03" diameter wire, is the same free height, and has the same wind angle (so same amount of coils) as our Tufftrucks. They are essentially the same spring that we have, by all accounts, and have been giving folks the same front end height as we got.
The stock springs are mostly in the .94" diameter range, from what I have seen, although we have heard of some that said they had seen some 1.0" ones. Stock springs have a higher wind angle, so less coils and stiffer, but take a set easier and are more progressive in springrate.
The "smoothing out the ride" comments are kind of a catch all term without the details necessary to decide if they are right for you, or not, IMO.
The backstory of it has to do with the design of the GM van front suspension, particularly the springing method. The vans have to be able to ride acceptably when empty, so softer springs would be nice, but they also need to be able to carry the big loads in a 1 ton van, so stiffer springs are needed. The way GM chose to address this paradox is to use softer springs but add a special bumpstop on the control arms to pick up the extra load when the soft spring gets compressed too far. It is a Timbren type urethane spring and very progressive in springrate because of it's limited height and travel. It sort/kinda works OK for a work van that sees varying loads, and is OK for empty vans as it is running on the softer springs then. On a fully loaded all the time van like a Class B, however, the front suspension is constantly bouncing off the very high springrate bump stops, which adds a very progressive spring in the middle of bumps, causing harshness and "pitching" of the front of the van. The shocks can't be tuned for both springrates, so seem to be set to match the softer springs more than the stiffer combination of spring and bumpstop, so the rebound off the bumpstop is much less damped than if it was shock matched, thus the pitching issue.
The net result of all the tech garble above is that the stock springs will likely be softer than an 81004 on small bumps, but harsher or the same on bumps larger than that because the bumpstop is getting hit. This is just for the softness, not the control or stability.
The 81004 is a non progressive spring so constant springrate, and with a lot of coils so more consistent over it's travel. With the 81004 in the van, it will ride nearly 2" higher, so the bumpstops don't get contacted on anything less than a huge bump, so there is no sudden change in springrate in the middle of a bump. The shocks will be damping against the same springrate all the time, so damping won't change over the travel, unless it is designed intentionally into the shocks.
What most of us describe would the with the 81004 springs, small bumps will get a bit harsher and the larger bumps will get less harsh and more controlled.
The 81004 (and our near duplicate Tufftrucks) seem to match very well with the stock replacement Bilstein shocks, as the designs are somewhat complimentary. The Bilsteins use variable damping that is set up to provide less damping on small bumps when you don't have travel control needed much, but want comfort. On the larger bumps, the damping increases to control the higher load and faster wheel motions and gives more control of the vehicle. Most feel the ride quality on big bumps isn't any worse than when on the bump stops all the time, but that the control and consistency is way better than stock.
So as you can see, the "smoother ride" is really an conglomeration of individual experiences, each of which is a very personally subjective item.
It does appear we have had very few, if any, real complaints on those that have used the 81004 springs concerning the ride and handling quality of them. Some wished raised the van more, but that is not what they were meant to do. As it turns out, they put the van just about right at the ride height that GM calls out in the factory service manual, so all the front suspension is right were it should be, geometry wise, for best handling characteristics.
As much as I like to compare factory specs on things, the spring rates that are out there for the different springs mystify me. I have not been able to even come close to duplicating the various rates across manufacturers when I use the spring specs and dimensions to calculate the springrate on a spring calculator program. It is very frustrating to say the least, and in Photog's thread gave us fits trying to guess what would happen with any given spring, based on the supplied spingrate.
While the rates between the OEM and the 81004 springs looks to be fairly close, depending on what place you get the rates, the results would indicate they are not all that close. The springs are the exact same free height, but the 81004 lifts the front end 1.75" on average (depends on how bad the front had sagged-they all end at the same height).
Hopefully, some of the folks that have recently switched to the 81004 springs will chime in with some more detailed impressions of ride quality under different conditions for you. If they also let you know which shocks they are running, that would be a big help also to putting the pieces together. Perhaps if someone lives near you, you might be able convince them to give you a test ride.:D Good luck on your quest!
I would contact AirLift. What I installed was a complete kit with the manifold and compressor together. I don’t know if that manifold could be used with a different compressor.
The manifold does provide power to the compressor. It powers it up when it needs air and then switches it off when it does not. I am not sure how you would get power to the compressor when you needed it for other uses. There may not be a adjustable pressure regulator in the manifold, it would be much cheaper to simply turn the compressor on when you needed more air and then switch it off when you got to your target pressure.
One solution for tying into the current air supply could be to run a line from the air tank to one(OK) but preferably two, air ride height control valves, one on each side. These are typically used on trucks/buses with air ride suspensions.
That is what we did, very handy and allows full pressure for tire filling and to the air powered spare tire lifter.
If you are in Socal we could arrange a test drive.
The front is harsh over small bumps such as uneven pavement and railroad tracks. Softer than it was, more like getting smacked with a rubber mallet when before it was like getting smacked with a ball-peen hammer.
Larger, less “sharp” bumps are handled very well. No porposing, very controlled. All movements are “once and done” with the suspension damping movements quite well. Roll is substantially reduced. Wind handling much improved. Ground clearance greatly improved. Road feel and stability is very good.
I have the Moog 81004, Bilstiens and LoadLifter 5000 AirLift bags.
It’s a really excellent upgrade. I would like to get the front more “cushy” but that may not be possible.
I am thinking of connecting a tank and an air hose to one of the airbag lines. I would set the airbags to the tire pressure that I wanted and fill up the tire with the air hose
i can’t think of a reason why it wouldn’t work.
If I am understanding the description, it sounds like as you filled the tire and the air tank lost pressure, so would your air bags. The control valves mentioned above prevent that from happening.
I installed the Moog 81004's in my '15 210, and it has been nothing short of great. With the OEM springs, if I had to jam down on the brakes, that front end would really go down - that has gone away - you hit the brake and it stops, or slows down as you desire....those new springs are much stronger. When Booster, Marko and the guys who know about these things put it out, I went for it - Moog Springs, Roadmaster Steering Stabilizer, Bilstein Shocks, and Airlift Ultimate Air Bags on the rear. It is a whole different ride, wish I had done it to the '05 190. Ron
They are just over $100 on Amazon, and maybe even less elsewhere, so that is not so bad, it appears.
It's down to $99.50 on Amazon today.
Could someone describe how to connect this gauge in an air lift system if I don't have an on-board compressor?
You lose a lot of th benefit of it without a compressor, but it would still work as a gauge to see leakage and to let air out of the bags if you wanted to.
You would have to hook it up with the airbag fill hose going to the inlet of the control and it would also need to be a clip on connection for the air hose or be within reach of the control.
You would put air into the fill port of the system from an air source and nothing would happen until you used the paddle valves to fill the bags. Then you remove the air source. At that point you would not be able to increase the bag pressure with the control.
Ron J Moore,CaDreaming and all,
Has anyone that did the Moog, Bilstein, + whatever in the back did this sequencially. Particularly, I am interested to know what the handling would be like after installing Moogs in the front and preferably something in the back to level off the rig but not installing Bilsteins right away. This test would tell us if the OE shocks would be overpowered by the stiffer coil springs up front.
There is no problem at all with doing it in stages, but is a good idea to do the lift on both ends at the same time as the alignment would change separately with each end and require being done twice if they are done separately.
My guess is that the springs will slightly overpower the front springs, maybe a bit more than slight if the shocks are shot, which can happen easily in less than 25K miles sometimes. You may not notice any overpowering happen, though, as you are used to low riding front end hitting the bump stops which will also overpower the shocks on medium to large bumps. My guess would be if the shocks are too weak for the springs you would notice it smaller dips as a bit of porpoising and maybe one wheel bumps would feel a bit disconnected. Bigger dips would likely porpoise now, but you probably have some of that already so might not be obvious. The most obvious thing you might see would be that you would still have the "pitching" on one wheel dips.
Whichever way it is, it really doesn't matter. If you like the way it drives with the OEM shocks, you just stay with them. If they feel a bit soft, you can then upgrade.
Booster,
I ordered the Moogs already. Still wondering what I will do in the rear to level off.
Forgot to mention that my 03 pop 190 has 70000 miles and the front is already sitting on the bump stops and the back sitting on the overload leaf when parked.
Could that change your educated guess about handling.
Regards
Booster,
Regards
Most of them are on the overload in the rear with full load, so that is typical. In the front, most ar a bit off the overload by a small amount. The further you are on the overloads on either end the firmer and more progressive you will be now, so you are on the high end there. The difference between before and after is harder to predict, but I would guess the front should less harsh, but some will depend on the shocks. At 70K, if the shocks are original, they are likely getting very weak so any new shocks would make it feel a lot firmer. Again, if original, the shocks would likely be having trouble controlling especially the rebound off the bump stops and they would also probably have trouble controlling the new springs. Your control in the front should be greatly improved with new spring and shocks, if the ones in there now are original.
What you get in the rear will be dependent on how you do the lift. Lift blocks will leave the ride about the same. New springs matched to the actual weight will probably be similar on smaller bumps but less progressive if they design the spring right (many shops go firmer than they need to), and airbags will get you up off the overload on small to medium bumps and should improve ride. On larger bumps with the bags, the overloads will still contact the springpack on larger bumps and does generate some noise and harshness, though. To get rid of that issue, you would have to remove the overload leafs, which is not a mainstream change at this point as AFAIK we are the only ones that have done that. I think that it would also increase the need you already have to add a rear swaybar to counteract the handling affects of a softer rear ride.
Booster, do I understand that;
1-If I go with air bags (rear) that I would be more in need of a sway bar but gain a more comfortable ride
2- If I just put 2in. blocks there I will not be in as much need of a sway bar but result in a harsher ride (think identical to original setup)
Thanks again for your educated guess. Anyway I go, people will know the end result as I am sure lots are looking for an affordable upgrade.
If you use air bags without removing the overload leaf in the springpack, the need for a swaybar won't really change much, if at all. It would change if you removed the overload to get better ride.
With the overload in place, if you raise the rear enough with airbags to get off of it with the rest of the pack, you will get slightly better ride, but only on smallish bumps with big ones not changing much.
The blocks will basically leave the rear springing as it is for roughness with perhaps a tiny loss in handling because of increased van height.
The need, or no need, for the rear swaybar will depend on if you want to change the handling characteristics of the van in the direction of reduced understeer, and secondarily to reduce rocking of the van in the wind. Understeer is in all the vans by design, but reducing it significantly is possible if you like driving a vehicle with less understeer like I do. Understeer symptoms are mostly how much steering wheel correction is needed to keep the van going in a straight line under various conditions. A stock van will probably be in the 1.5" steering wheel motion if the steering wheel parts are tight, and a van with lessened understeer may be as low as 1/2" of steering wheel motion. Some like the bigger motions and find the smaller ones to give "twitchy" handling, while others say the big motions are like driving a boat, so very personal perception based. Think of it as the difference between driving a "twitchy" BMW vs driving a "boaty" old rear drive Buick.:D
If you have a generator in place, adding a rear swaybar can get very expensive. Without a generator it is much less, but still not a cheap option.
Booster,
Regarding air bags, I understand you seem to be the only one who has removed the overload leaf. What would be the pertinence of having the internal jounce type air bags if one does not remove the overload leaf ? It seems redundant to me.
Could I cause dammage to the air bags ?
  • and much more...
Try RV LIFE Pro Today
Back
Top
