Just finished my Roadtrek 210 grille upgrade. I wanted to change to the GMC grille as it has more open area than the Chevrolet version, so hoping to get better cooling with this grille. I didn't have the GMC emblem, so instead of buying one I decided to customize the grille with the existing Roadtrek emblem that is on the hood. I used a heat gun to help remove the emblem from the hood. I filled in some holes on the central emblem mount area on the grill. Then vinyl wrapped with a carbon fiber wrap material. First time I ever wrapped anything and it turned out OK.
Made an emblem holder from some 1/8" aluminum plate stock. Had to bend it slightly to have it fit the contour of the grill emblem area. Drilled and mounted two flat-head countersunk bolts to mount the holder on the grill. Glued the emblem on the holder with emblem glue. Attached the emblem to the grille and mounted the grille on the van.
Here is the link to Booster's cooling upgrade post.
http://www.classbforum.com/forums/f8/oil-and-tranny-coolers-particularly-chevy-6402-2.html
