Cheap fix for cabinet supports
reilym
Senior Member
Joined
Mar 24, 2019
Posts
110
Location
MI
Like many, I got frustrated with the Hafele supports that eventually failed to hold our cabinet doors open. After enough knocks on the head, I decided to do something about it. I got this idea of using stiff spring stays off of an online Pleasure Way Forum. After looking into commercial spring stays, I was a bit put off by paying ~$30/door and having to drill new mounting holes, so being the cheap SOB that I am, I got to thinking. I wound up replacing the support mechanisms with springs, reusing the original mounts and could not be happier. Total of 1 hour and $20. Go here for a complete write up.
For hardware, I bought s six pack of springs ($12) and some braided sleeving ($8.00)
How does the spring bend in the proper direction to spring the door open? It looks like it could bend in any direction.
I had the same problem. I used these tried-and-true spring loaded door struts. They are inexpensive and made for RV use - they have been used in RVs for decades.
Unlike the springs, they simply compress straight down without bending outward.
If you install them correctly, they will move slightly past bottom dead center as the door closes, thus creating spring pressure on the door to stay closed. So they will both hold the door open (fully extended), and also hold the door closed (partially extended).
Simple, low-tech device that works perfectly.
Because the spring "eyes" are parallel to the side wall of the cabinet, the spring naturally hugs the cabinet wall when you push on it. I'll play around with pushing from different directions and report back. But, so far when I push toward the back of the cabinet, the springs just collapse along the inner cabinet wall. These are really sturdy supports when fully extended, but inadvertently hitting one will cause the cabinet door to close abruptly which is admittedly a downside to this solution.
  • and much more...
Try RV LIFE Pro Today
Back
Top
