Leland-ClassB
Advanced Member
Thanks for the info. Is Roadtrek stopping production with the Chevy Express in the next few years? Are they coming out with a Transit version? If so, are there any details? Thanks again
So its day two of the Tampa show, Roadtrek has a press release about the Haven, but I can't find nor have I seen anything about it on the web. Anybody, anybody? (insert cricket noise here)
Based on the poor build quality of past Roadtrek rollouts, it is possible that Thor figured the unit was not quite ready to be shown yet.
HA HA as only an AS owner could know.The problem with that theory is that the only company with lower initial build quality standards than RT is Thor.![]()
Does anyone know if there is any difference in size for the fiberglass drivers side storage compartment door between a 1999 Dodge Roadtrek 190 vs. 170 (or any model year around this time). The 190 Dodge itself is longer and wider than the 170, but it looks to me that the storage compartment is the same, with a door length of about 56 1/4". Does anyone know offhand, or have a 190 they can measure? Thanks!
I need to reset the rear window of my 2000 Roadtrek popular and need to know how to remove and reset it. Thanks ahead of time.
Ron
Looks like I'm a couple months late, but just in case you're still looking for an answer...
I've got a 1999 RT Versatile 190 on the Dodge chassis. I measured that for tonight as 56". The opening is probably 56-1/4", allowing for 1/8" clearance on either end.
