What probably happened to you was a faulty replacement job. Some mechanics don't know/care that some of the mounting bolts are one use only. If they are re-used, they will soon fail.
I know that there are aftermarket rebuilt engines that are considered good as new. There may also be such for transmissions. Your transmission is also common to several other vehicles. An independent mechanic might get you back on the road far sooner than a dealer.
If the 2022 Solis on a '21 or '22 chassis? There is a recall on, IIRC, 2019-21 for parking pawls that break down and introduce debris. Our 2014 has 258,250 miles on the same transmission. Fingers crossed.
