Water near refrigerator at night in Entegra Ethos LI
RS_SMS
Joined
Dec 30, 2024
Posts
2
Location
AZ
We recently bought an Entegra Ethos LI. I had water leaking from the water heating box that I was able to repair and don't see any other leaks. At night when the Timberline heater is used I'm getting water (maybe a handful of ounces) from under the refrigerator. Is there a drain from the refrigerator that could be plugged or could water be condensing from the heater use? It isn't much water but I want to stop this before it does damage something. We're in AZ where it's pretty dry so I'd be surprised if it was condensation. The sink is on top of the refrigerator and no leaks are visible from that. Any ideas? Thanks!
GeorgeRa, Thanks for the comment. I had the van hooked to shore water. I had the panel next to the sink faucet off so I could see no water coming from the supply or drain lines. My next step is probably going to be removing the refrigerator and seeing if that shows me anything.
I don’t how easy access is to plumbing and here are some potential options to verify the source of the leak:
1. Drain water and pressurize the system with compressed air, just like for winterizing and listen for a hiss
2. or disconnect shore connection and check again for overnight leak
3. or Use endoscope camera to see inaccessible space https://www.amazon.com/Inspection-F...d2lkZ2V0TmFtZT1zcF9zZWFyY2hfdGhlbWF0aWM&psc=1
4. or install a pressure gauge and monitor pressure decay. https://www.amazon.com/Pressure-Uni...+by+pressure+decay&qid=1735606980&sr=8-3&th=1
Water leak
Hi , I too had a leak in my Ethos Li , it turned out to be a hose connection onto the taps. I believe the fridge had to be pulled to get at the bottom of the taps. The microwave is not that hard to get out, you might be able to reach bottom of taps from that opening.
  • and much more...
Try RV LIFE Pro Today
Back
Top
