wincrasher
Senior Member
Well I said I was going in a different direction and here it is! I bought a 2000 Xplorer 230 XLW. It is the most cherry one I've ever seen and has 60k miles on the clock. Interior and exterior are in excellent shape.
Why not a new van? Well, I have 68,000 reasons!
What drew me to this one was condition and some of it's features. Excellent exterior storage including a slide-out tray. No generator, so a second large exterior compartment.
Factory installed inverter. Water heater on AC or engine heat - so no exterior access panel. 12v/110v fridge, so no exterior fridge vents. Small solar panel with trickle charger. The layout has the rear folding sofa, so that is a queen. That leaves room for two large hanging wardrobe and a pull-out pantry cupboard.
From what I see under the hood, it looks like there is an isolator to charge the house batteries.
So what to do with this one? Some ideas I have: install 4 drop-in lithiums (I have these already in my shop, so no extra $), plus a new charger/converter to go with them. Remove carpets and install hard flooring.
Should I upgrade the alternator? See if there is a 2nd alternator kit for these old Ram vans? Should I remove the stripes/graphics? Paint it? Rhino liner it? Leave it as is?
Not sure solar is really worth the trouble. I'm a weekender, so not really sitting in one place very long. Engine idling may be enough power generation. I do have a portable generator (Yamaha) I can carry if I get in a jamb.
Suggestions welcome.
