Old 08-29-2024, 04:36 PM   #1
Default How to remove exterior faucet 95 RT Chev Popular
Hi everyone. How would I go about opening this "box" that appears to be 1 piece, so I can replace the faucet? Looks like plumbing and electrical all going in there. Thanks!
Also, would this replacement work?
capeApe is offline   Reply With Quote
Old 08-29-2024, 05:06 PM   #2
I don't have a Roadtrek, but from looking at it, I'd bet that the black plate is snapped into place. Maybe gently pry with a standard dcrewdriver to see if it pops out, revealing the backside where the nuts hold the faucet in place.
The Eyesore is offline   Reply With Quote
Old 09-05-2024, 10:40 PM   #3
On some of those faucets the cartridges are replaceable.
Dumb question, is it possibly accessible from inside?
ccourcier@gmail.com is offline   Reply With Quote
Old 09-05-2024, 11:49 PM   #4
It just looks like a train wreck and I have other plumbing to do after it’s repaired so I can’t risk “fixing it” not working.
The hot water tank is located right above this entire area.
Old 09-06-2024, 04:04 PM   #5
There is access from undercarriage, in front of rear wheel. A very tiny hole you can barely fit your hand through to access the lock nuts and plumbing nuts. You can't see, can only fit 1 hand if you're lucky, and barely any tool
Old 09-06-2024, 04:21 PM   #6
Oh man, that doesn't look fun, at all! Haha! You're really gonna appreciate that shower, when you're done.
