We have been using Basecamp to do routes on the laptop, where they can be easily customized to our selected path, to transfer to the GPS for navigating. As anyone who has used the program knows, it can be very counter intuitive, and help is nearly nonexistent.
There have been two things that I really wanted to be able to do, but hadn't been able to get to work. Both are related to long, fully customized, routes.
The first was to be able to add a waypoint in the middle of customized route, without the entire route recalculating and dumping all our selected roads. The second was to be able to copy out a segment of the route to use. That way I could make a multiday trip, we could do as much, or little, of it as we got to, and the next day start from where we left off. You can do that in the GPS itself by selecting where to from the list, but it will freelance to that point, and sometimes redo the entire route for some reason.
Anyway, I got both to work today (it is raining, so nothing useful to do).
To add a waypoint to a custom route; Create a the new waypoint, it should show up in the left panel with the route and the other waypoints. Left click and hold on the waypoint and drag it to the route you want to add it to in the left panel. When you are over the route a + will show and the route box will show up over the map. Drag the waypoint to the route box and insert it into the route. You will see a line where it is going to be, so you can drop it where you want if it is visible. If not visible, just drop it anywhere and use up/down arrows to move it to where you want it. Hit recalculate and the route will stay the same, with the exception of going to the new waypoint.
To copy out just a segment of a long route and make it a new route. Open the route so you have the route box open to the "properties" tab with "more info" checked. Click to highlight the beginning of the new route on the route list in the route box. Use shift-click to highlight the end of the new route from the list. All the points between the items should highlight. Right click and copy the highlighted items.
No go to someplace wide open on the map, like an ocean, and create two new waypoints. They should show up in the left panel with the other waypoints and routes. Create a "dummy" route with the two points. Open that route and get the route box, which will just show the two points. Right click, paste, the previously copied points into the dummy route. They will show up below the two ocean waypoints. Delete the two ocean waypoints and all that is left is the copied part of the long route, including all the via and shaping points to make it custom. Click recalculate and the route will be made and show up in the left pane.
We will be trying out these on our long trip this year, but I think it is going to make life even easier for us.
