- Joined
- Jul 24, 2013
- Posts
- 5,434
I agree that on the surface at least, this report seems absurd. I recently carefully measured all of my loads. My entire TV consumes 1.5 amps; my propane solenoid valve consumes .7 amps (and most electrical relays typically use much less than that); my Fantastic Vent on "high" uses 2.8; my 2800 watt inverter on idle uses 2.3. The only DC load in the whole van that consumes anything like 6 amps is my large NovaKool compressor refrigerator, and that only when running. I don't see how you could make the battery controller consume 6 amps if you tried. There has got to be more to this story.
I've always thought that the RT design of separate controls for each battery was a kluge. I am no big fan of heavy automation in a B-van (one of the reasons we decided against an ARV), but that is too much even for me.
